Old 12-06-2008, 06:37 PM   #151 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
Originally Posted by TestDrive View Post
Have you given up on the "second windshield" / aero-visor?
Was the proto-type aero-visor still in use when you hit the deer?
I was getting ready to make improvements on and reinstall the "second windshield" when I had the wreck, which ate up the parts, time, and funds I had budgeted for that project. Perhaps this spring I'll get back to it again.
Its been over a year and a half since I had the "second windshield" installed so it wasn't on when I hit the deer.
aerocivic.com
Old 12-06-2008, 06:48 PM   #152 (permalink)
basjoos's Avatar
  1. Does the rear hatch latch from the exterior of the vehicle? If so, could you show a close-up.
  2. Is there duct work connecting the variable air inlet in the nose piece with the radiator?
  3. How large was the deer? Fawn, yearling, two-four years old, a big ol' one?
  4. Would you please take front and side view of the front with the engine cover raised? (Basically, I'm interested in the upper radiator support.)
Thanks in advance.
The rear hatch uses the original hatch's hinge. I just removed that black plastic spoiler at the top of the original hatch and attached the lexan to the metal hinge frame that originally held the spoiler.
The air inlet empties into the interior of the nosepiece and then enters through the original grill openings. The original bumper and grill are still in place under the nosepiece.
The deer was a full grown doe.
I'll take some pictures on Monday when I get off work. My nosepiece is attached to top, sides, and bottom of the plastic of the original front bumper and its upper edge runs just below the headlights and the front of the hood.
aerocivic.com
Old 12-06-2008, 07:43 PM   #153 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by Christ View Post
I'm not sure what the Insight's engine layout code is, or how exactly the mouting system is designed, but I do know that it requires expensive engine management controls, and I've yet to see anyone actually get one to work perfectly in another chassis.
But you know of some who have tried? Could you point me to more info - I'd be really interested in seeing that.
Old 12-06-2008, 08:10 PM   #154 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
I probably didn't express my question too clearly. What keeps the rear hatch from bouncing open when you go over a speed bump a little too fast?
Old 12-06-2008, 09:52 PM   #155 (permalink)
basjoos's Avatar
The hatch was held closed by a hatch release pin that is connected to the car's original hatch release actuator cable. I haven't had time to rebuild the release pin mechanism since the wreck, so the the hatch is currently held shut by two screws. I've made all of the parts for the pin release mechanism and plan to get it installed this week.
aerocivic.com
Old 12-06-2008, 10:06 PM   #156 (permalink)
basjoos's Avatar
The nice thing about the aluminum bar and sheet construction is that it takes a very small and inexpensive tool set to do it. Everything added onto my car has been builrt with the following toolset: jigsaw, cordless drill (and drill bits), heat gun (for heat setting coroplast and lexan), hacksaw, tin snips, 2 large pipe wrenches (for bending aluminum bar), measuring tape, pipe taps, tap holder, box cutter (for cutting coroplast), philips screwdriver, pop rivet gun, paint brush, and caulk gun.
aerocivic.com
Old 12-07-2008, 02:45 AM   #157 (permalink)
What were the pipe taps used for?
Old 12-07-2008, 04:14 PM   #158 (permalink)
basjoos's Avatar
Cutting threads for 8-32 screws in the holes I drilled in the aluminum bar.
aerocivic.com
Old 12-07-2008, 07:25 PM   #159 (permalink)
Ok. Now I understand.
The nomenclature must be different in SC. Any place I've been "pipe taps" could only refer to standard plumbing tapered pipe taps.
Old 12-07-2008, 07:37 PM   #160 (permalink)
basjoos's Avatar
I should have said "hand tap". "Pipe tap" is a generic term for any sort of tap among some of the folks I work with.
aerocivic.com
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
Posted By For Type Date
Aerocivic - how to drop your Cd from 0.31 to 0.17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 01-23-2012 08:53 AM
Week of November 21st - November 27th, 2011 (Nat Avg $3.37) - Page 4 - CleanMPG Forums This thread Refback 11-25-2011 11:27 AM
Overdrive.fiョ | N艙t viesti - Pisaralla pisimmlle -jenkki This thread Refback 10-12-2011 03:58 AM
Anyone have a 1.7 cdti ? • Honda Civic Forum This thread Refback 10-05-2011 07:07 PM
Improving MPG - Page 2 This thread Refback 10-03-2011 11:09 AM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Chevrolet Impala SS Forum : Chevy Impala SS Forums This thread Refback 09-23-2011 01:53 AM
Slippery Eg Civic | RMS Forum This thread Refback 09-15-2011 04:56 PM
Fuel vapour carburetor ?? Any thoughts? This thread Refback 09-07-2011 03:38 AM
Ecotuning This thread Refback 08-30-2011 04:12 PM
DIY metro aero body This thread Refback 08-09-2011 10:17 PM
Outside Rear View Mirror - Red Pepper Racing This thread Refback 07-27-2011 11:00 PM
Aerocivic How To Drop Your Cd From 031 To 017 Page 41 Fuel This thread Refback 07-24-2011 11:12 AM
www.neons.org • View topic - My ecomodded neon. Tire spats & mini folding mirror install. This thread Refback 06-26-2011 10:16 AM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-22-2011 02:09 PM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-17-2011 06:46 PM
???????????????????????????????????????? ?????? - ??????Days This thread Refback 05-15-2011 06:05 AM
、ネ、テ、ニ、箍ツチエ、ハ・ユ・ァ・・タ。シ・゚・鬘シシヨ、ャタ萠ヌタ」チー。「・ノ・「・゚・鬘シ、ネ、ォエ、ハ、、、タ、ア、ヌ、ケ、陦ト。ト。ェ ・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 05-11-2011 10:13 AM
archives for 07/2009 This thread Refback 04-16-2011 04:56 PM
・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 04-10-2011 10:15 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 04-07-2011 01:10 AM
???????????????????????????????????????? : ?????? This thread Refback 04-01-2011 06:51 AM
Your answer to rising gas prices! This thread Refback 03-19-2011 03:45 PM
Project MMPG ~Slow build thread This thread Refback 03-07-2011 08:05 PM
I'm Dac Biet This thread Refback 03-07-2011 06:19 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 03-06-2011 06:43 AM
Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 02-24-2011 05:49 PM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-09-2011 12:35 AM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-08-2011 11:01 PM
Tobias Laboratories サ 1989 Geo Metro This thread Refback 02-04-2011 06:43 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 01-30-2011 07:41 PM
Motorbyte i moppebil - generatorfrgor This thread Refback 01-08-2011 07:09 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 01-05-2011 04:37 AM
The Nissan Path :: View topic - What octane gas do you use? This thread Refback 12-27-2010 11:43 PM
www.neons.org • View topic - ...AERODYNAMIC FAIL! This thread Refback 12-15-2010 12:19 PM
blekko | honda insight mpg at 70mph This thread Refback 11-14-2010 04:16 PM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-14-2010 06:37 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 10:18 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 07:24 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 04:58 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:56 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:53 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:40 AM
ュサエ莢Qスラーマ Discuss.com.hk This thread Refback 11-13-2010 12:40 AM
forum.group44.de • Thema anzeigen - Surftipp fr Aerodynamik- & Sparfreaks This thread Refback 10-18-2010 11:54 AM
XINeons.com View topic - custom bumper idea This thread Refback 10-08-2010 11:07 PM
Improving MPG This thread Refback 09-15-2010 01:19 AM
The 100 mpg carb - Does it really exist? This thread Refback 08-11-2010 11:16 PM
So, we haven't bashed Prius' in a while ... - LS1GTO.com Forums This thread Refback 07-27-2010 01:27 AM
1962 Mustang images & 1962 Mustang stock photos at HealthHaven.com This thread Refback 07-20-2010 10:12 PM
New transport secretary = idiot Singletrack Forum This thread Refback 06-02-2010 05:06 AM
AlterSlash ~ the unofficial SlashDot digest This thread Refback 05-31-2010 06:29 PM
www.neons.org • View topic - My ecomodded neon. Thinking about an aero front bumper... This thread Refback 05-31-2010 06:24 PM
Slashdot | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:44 AM
Slashdot Comments | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:35 AM
Slashdot Hardware Story | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 08:44 AM
新型プリウスで東京〜鹿児島〜熊本の無給油燃費記録に挑戦 This thread Refback 05-27-2010 08:10 AM
Improving MPG - Page 2 - Ranger Power Sports Forum This thread Refback 05-26-2010 12:57 AM
Your answer to rising gas prices! This thread Refback 05-11-2010 01:40 PM
Project Super zuinig... - Afdrukversie This thread Refback 04-04-2010 12:12 PM
L'aerodinamica della Civic This thread Refback 03-10-2010 07:17 PM
Wykop.pl - Ekonomiczny Civic spala tylko 2,5l litra benzyny na 100km - Powi?zane This thread Refback 02-22-2010 06:57 PM
www.HondaTuning.lt - View topic - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 02-21-2010 12:08 PM
I have yet to see a thread address this - TDIClub Forums This thread Refback 02-19-2010 01:55 PM
Aerodynamics (Project KITT) This thread Refback 02-09-2010 10:08 PM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Impala SS Forum This thread Refback 02-09-2010 07:55 PM
Homesteading Reviews This thread Refback 02-07-2010 11:25 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co mo?emy poprawi?? This thread Refback 02-05-2010 04:34 PM
【燃費】まじめに燃費向上を語り合うスレ 37km/L This thread Refback 02-04-2010 12:28 PM
I have yet to see a thread address this - Page 2 - TDIClub Forums This thread Refback 01-20-2010 07:23 AM
electroauto.ru :: ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 01-16-2010 08:05 AM
I have yet to see a thread address this - TDIClub Forums This thread Refback 01-10-2010 03:37 PM
Do it yourself aero modification This thread Refback 01-02-2010 02:55 PM
??????[??]?????????????????? This thread Refback 12-14-2009 04:23 AM
www.neons.org • View topic - My ecomodded neon. Insight tire teaser! 11-21-09 This thread Refback 11-23-2009 11:28 PM
Tailboxes work for everyone - 'BentRider Online Forums This thread Refback 11-18-2009 03:00 PM
Untitled document This thread Refback 11-17-2009 08:04 AM
Noul Logan Renault eco2, cu 3,8% consum - DaciaClub - Forum Dacia This thread Refback 11-12-2009 04:45 AM
electroauto.ru • ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 11-10-2009 11:41 AM
菴守雋サ縺ァ襍ー繧後k繧医≧縺ォ謾ケ騾縺輔l縺溘お繧「繝ュ繧キ繝薙ャ繧ッ縺ョ蜀咏悄 - darkwater 縲 縺ソ繧薙き繝ゥ 縲 繝悶Ο繧ー This thread Refback 11-04-2009 11:34 AM
Motorbyte i moppebil - generatorfr虍or This thread Refback 10-06-2009 01:23 PM
Rad blind experiment - MBClub UK Forums This thread Refback 09-25-2009 03:42 AM
www.hondatuning.lt :: Perirti tem - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 09-03-2009 10:48 AM
www.neons.org • View topic - My hypermiler. Rapid acceleration is better! This thread Refback 09-01-2009 02:56 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 08:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 01:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 09:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
