Old 12-14-2007, 04:19 PM   #11 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
After you swap out to LED park lights if you want to reduce the headlight load you can wire up some relays to switch them to series load instead of parallel. That will make them dimmer but not really dark. It will cut the load in half though
The other thing would be using some relays to switch them out you can add several silicon diodes in line. You get a .7V drop across a diode so add 5 of them in series will drop you 3.5V. Just make sure to pick big enough diodes to handle the load.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 12-14-2007, 04:20 PM   #12 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I've heard of an instance where a university team solar car was forced off the road due to rubbernecking. Ended up catching a culvert and flipping the solar car. Fortunately nobody was hurt.
EDIT: the comparison of your Civic to a solar car (in terms of aero optimization) isn't that much of a stretch either either.
Old 12-14-2007, 05:31 PM   #13 (permalink)
Peakster's Avatar
'99 Intrepid - '99 Intrepid
90 day: 23.1 mpg (US)
Whatever happened to your additional 'wind screen' :
Old 12-14-2007, 05:33 PM   #14 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Rain?
Old 12-14-2007, 05:41 PM   #15 (permalink)
Peakster's Avatar
Originally Posted by SVOboy View Post
Rain?
Mmm. I don't think so. Not according to this previous post by basjoos:
The second windshield added about 4mph to my terminal velocity on the "calibrated" downhills on my drive. I drove through some light rain and didn't even notice it on the vinyl other than the occasional drop running back along the vinyl. Most of th rain (and bugs) follows the smooth airflow over the vehicle. And best of all, no evidence of the "A" pillar vortex based on the behavior of the water droplets on the front side windows.
Old 12-16-2007, 08:44 PM   #16 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
Coyote X, good idea about using series connecting the headlights and also using doides to customize the voltage drop.
The aero benefits of the "second windshield" (by eliminating the "A" pillar vortex and smoothing the airflow over the front of the car) were undeniable, but I had some operational problems with it when operating in cold rainy weather. I'm in the process of replacing the clear vinyl on the "windscreen" with Lexan. The vinyl was clear enough when looked at straight through (90 degrees), but was hazy when viewed through at an angle (30 degrees) as it is near the bottom of the windscreen. It also had a tendancy to overwealm the Fog-X and fog up on the inner surface when driving in cold, wet conditions. The Lexan should take care of the low angle visibility problem and I need to get a good watertight seal along the front and sides of the "windshield" so water can't find its way onto the hot hood and end up condensing on the cold inner surfaces of the "windshield". Also considering adding a windshield wiper to the "windshield" to placate any cops that might freak out at a car driving in the rain without wipers, even if I don't really need them.
aerocivic.com
Old 12-16-2007, 10:28 PM   #17 (permalink)
The Mighty Mira - '92 Mira
90 day: 61.32 mpg (US)
Basjoos, you might want to stick a sock full of crystalline kitty litter (it's silica gel, the cheapest source you can find) somewhere in that space to get rid of any lingering moisture that finds its way in there.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
Old 12-26-2007, 08:20 AM   #18 (permalink)
I read this and was so impressed I had to write about it on my blog.
You can read my thoughts at http://www.energyrefuge.com/blog/caf...-be-that-hard/
Old 12-27-2007, 08:26 PM   #19 (permalink)
Nice.
I was recently thinking about wheel spoilers and I thought of something I think is relevant.
Your front wheel spoiler mostly pushes air down, where it will end up hitting the tire (or ground) still anyway. I believe that won't help you any, and that it would be more efficient to just push the air directly to both sides of the wheel. Possibly more to the outside of the car than under the car due to the rest of your aerodynamics. So you would have a wedge where the leading edge is a vertical line.
And I would expect you to benefit from putting another set of spoilers behind the rear wheels (working well with your dual layer side skirts).
Of course I have no idea if these would give you enough benefit to be worth you doing.
Old 12-27-2007, 08:33 PM   #20 (permalink)
That's a good observation for behind the rear tires. But do you mean to add a "boat tail" rather than "spoiler"?
You'll see wheels/tires effectively boat tailed on this car:
http://www.design-classic-cars.de/auto-union/stuck1.jpg
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
Posted By For Type Date
Aerocivic - how to drop your Cd from 0.31 to 0.17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 01-23-2012 08:53 AM
Week of November 21st - November 27th, 2011 (Nat Avg $3.37) - Page 4 - CleanMPG Forums This thread Refback 11-25-2011 11:27 AM
Overdrive.fiョ | N艙t viesti - Pisaralla pisimmlle -jenkki This thread Refback 10-12-2011 03:58 AM
Anyone have a 1.7 cdti ? • Honda Civic Forum This thread Refback 10-05-2011 07:07 PM
Improving MPG - Page 2 This thread Refback 10-03-2011 11:09 AM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Chevrolet Impala SS Forum : Chevy Impala SS Forums This thread Refback 09-23-2011 01:53 AM
Slippery Eg Civic | RMS Forum This thread Refback 09-15-2011 04:56 PM
Fuel vapour carburetor ?? Any thoughts? This thread Refback 09-07-2011 03:38 AM
Ecotuning This thread Refback 08-30-2011 04:12 PM
DIY metro aero body This thread Refback 08-09-2011 10:17 PM
Outside Rear View Mirror - Red Pepper Racing This thread Refback 07-27-2011 11:00 PM
Aerocivic How To Drop Your Cd From 031 To 017 Page 41 Fuel This thread Refback 07-24-2011 11:12 AM
www.neons.org • View topic - My ecomodded neon. Tire spats & mini folding mirror install. This thread Refback 06-26-2011 10:16 AM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-22-2011 02:09 PM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-17-2011 06:46 PM
???????????????????????????????????????? ?????? - ??????Days This thread Refback 05-15-2011 06:05 AM
、ネ、テ、ニ、箍ツチエ、ハ・ユ・ァ・・タ。シ・゚・鬘シシヨ、ャタ萠ヌタ」チー。「・ノ・「・゚・鬘シ、ネ、ォエ、ハ、、、タ、ア、ヌ、ケ、陦ト。ト。ェ ・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 05-11-2011 10:13 AM
archives for 07/2009 This thread Refback 04-16-2011 04:56 PM
・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 04-10-2011 10:15 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 04-07-2011 01:10 AM
???????????????????????????????????????? : ?????? This thread Refback 04-01-2011 06:51 AM
Your answer to rising gas prices! This thread Refback 03-19-2011 03:45 PM
Project MMPG ~Slow build thread This thread Refback 03-07-2011 08:05 PM
I'm Dac Biet This thread Refback 03-07-2011 06:19 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 03-06-2011 06:43 AM
Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 02-24-2011 05:49 PM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-09-2011 12:35 AM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-08-2011 11:01 PM
Tobias Laboratories サ 1989 Geo Metro This thread Refback 02-04-2011 06:43 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 01-30-2011 07:41 PM
Motorbyte i moppebil - generatorfrgor This thread Refback 01-08-2011 07:09 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 01-05-2011 04:37 AM
The Nissan Path :: View topic - What octane gas do you use? This thread Refback 12-27-2010 11:43 PM
www.neons.org • View topic - ...AERODYNAMIC FAIL! This thread Refback 12-15-2010 12:19 PM
blekko | honda insight mpg at 70mph This thread Refback 11-14-2010 04:16 PM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-14-2010 06:37 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 10:18 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 07:24 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 04:58 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:56 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:53 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:40 AM
ュサエ莢Qスラーマ Discuss.com.hk This thread Refback 11-13-2010 12:40 AM
forum.group44.de • Thema anzeigen - Surftipp fr Aerodynamik- & Sparfreaks This thread Refback 10-18-2010 11:54 AM
XINeons.com View topic - custom bumper idea This thread Refback 10-08-2010 11:07 PM
Improving MPG This thread Refback 09-15-2010 01:19 AM
The 100 mpg carb - Does it really exist? This thread Refback 08-11-2010 11:16 PM
So, we haven't bashed Prius' in a while ... - LS1GTO.com Forums This thread Refback 07-27-2010 01:27 AM
1962 Mustang images & 1962 Mustang stock photos at HealthHaven.com This thread Refback 07-20-2010 10:12 PM
New transport secretary = idiot Singletrack Forum This thread Refback 06-02-2010 05:06 AM
AlterSlash ~ the unofficial SlashDot digest This thread Refback 05-31-2010 06:29 PM
www.neons.org • View topic - My ecomodded neon. Thinking about an aero front bumper... This thread Refback 05-31-2010 06:24 PM
Slashdot | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:44 AM
Slashdot Comments | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:35 AM
Slashdot Hardware Story | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 08:44 AM
新型プリウスで東京〜鹿児島〜熊本の無給油燃費記録に挑戦 This thread Refback 05-27-2010 08:10 AM
Improving MPG - Page 2 - Ranger Power Sports Forum This thread Refback 05-26-2010 12:57 AM
Your answer to rising gas prices! This thread Refback 05-11-2010 01:40 PM
Project Super zuinig... - Afdrukversie This thread Refback 04-04-2010 12:12 PM
L'aerodinamica della Civic This thread Refback 03-10-2010 07:17 PM
Wykop.pl - Ekonomiczny Civic spala tylko 2,5l litra benzyny na 100km - Powi?zane This thread Refback 02-22-2010 06:57 PM
www.HondaTuning.lt - View topic - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 02-21-2010 12:08 PM
I have yet to see a thread address this - TDIClub Forums This thread Refback 02-19-2010 01:55 PM
Aerodynamics (Project KITT) This thread Refback 02-09-2010 10:08 PM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Impala SS Forum This thread Refback 02-09-2010 07:55 PM
Homesteading Reviews This thread Refback 02-07-2010 11:25 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co mo?emy poprawi?? This thread Refback 02-05-2010 04:34 PM
【燃費】まじめに燃費向上を語り合うスレ 37km/L This thread Refback 02-04-2010 12:28 PM
I have yet to see a thread address this - Page 2 - TDIClub Forums This thread Refback 01-20-2010 07:23 AM
electroauto.ru :: ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 01-16-2010 08:05 AM
I have yet to see a thread address this - TDIClub Forums This thread Refback 01-10-2010 03:37 PM
Do it yourself aero modification This thread Refback 01-02-2010 02:55 PM
??????[??]?????????????????? This thread Refback 12-14-2009 04:23 AM
www.neons.org • View topic - My ecomodded neon. Insight tire teaser! 11-21-09 This thread Refback 11-23-2009 11:28 PM
Tailboxes work for everyone - 'BentRider Online Forums This thread Refback 11-18-2009 03:00 PM
Untitled document This thread Refback 11-17-2009 08:04 AM
Noul Logan Renault eco2, cu 3,8% consum - DaciaClub - Forum Dacia This thread Refback 11-12-2009 04:45 AM
electroauto.ru • ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 11-10-2009 11:41 AM
菴守雋サ縺ァ襍ー繧後k繧医≧縺ォ謾ケ騾縺輔l縺溘お繧「繝ュ繧キ繝薙ャ繧ッ縺ョ蜀咏悄 - darkwater 縲 縺ソ繧薙き繝ゥ 縲 繝悶Ο繧ー This thread Refback 11-04-2009 11:34 AM
Motorbyte i moppebil - generatorfr虍or This thread Refback 10-06-2009 01:23 PM
Rad blind experiment - MBClub UK Forums This thread Refback 09-25-2009 03:42 AM
www.hondatuning.lt :: Perirti tem - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 09-03-2009 10:48 AM
www.neons.org • View topic - My hypermiler. Rapid acceleration is better! This thread Refback 09-01-2009 02:56 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 08:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 01:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 09:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
