Old 03-05-2009, 02:30 PM   #231 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
The instructions for measuring the drag of your car doesn't seem to take account of the air temperature -- does this matter?
Old 03-05-2009, 02:38 PM   #232 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Air temperature and pressure do have some effect on drag. You can get an idea of the magnitude of the differences from the aero/rolling resistance calculator tool.
Mike: the continued evolution makes the car eligible for next month's Modification of the Month contest.
Old 03-05-2009, 03:56 PM   #233 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Are those mini-boattails on the clearance lights?
Old 03-05-2009, 06:46 PM   #234 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by basjoos View Post
Added another minor aero tweak. I took a page out of Aptera's book and installed ducts to exhaust my cabin air into the small low pressure eddy behind the license plate. I doubt I will notice any difference in mileage, but every little bit helps and it should help to move the cabin air with less fan assist.
Vent holes at back of cargo area.
I was wondering when you were going to do that sort of modification.
If I ever get around to building an EV, I plan to have dryer ducting that goes from my 'grille' to the back end of the car using the ICE exaust channel.
Hopefully this would create a 'ram-air' sort of effect to help fill in the wake around the rear plate.
I'm sure there is a way that you could come up with something similar.
Do you think something like that would even be worth it though ?
Old 03-05-2009, 09:10 PM   #235 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
The clearance lights are faired on their leading and trailing ends. Every little bit of drag reduction helps.
aerocivic.com
Old 04-22-2009, 02:33 PM   #236 (permalink)
Basjoos,
I've noticed another member following in your footsteps and I have a question regarding your engines. Both of you started with CX models implying the 8 valve non-Vtec-E engine. Have you swapped the engine to a different one... VTEC-E ?
I owned a CX for awhile, and I got about 42 mpg on flat runs down I-5 and around 33-36 over mountain passes. I have never owned a VTEC-E engined car but they are rated higher mpg than the CX.
If you are not running the lean burn technology, I think there is more yet to be gained over your accomplishments utilizing it + starting with a CRX chassis instead of the EG hatchback.
I am working with autocad attempting to design a rear engined aluminum unibody aero car based on civic parts. I imported engines from Japan as a business several years ago and found several options we don't have in the USA, like the 3-stage VTEC
D15B and the Civic EL engine which is a 70HP 16V 1.3L D13B offered in the 96-98 hatchback in Japan.
Old 04-22-2009, 04:52 PM   #237 (permalink)
basjoos's Avatar
The current engine in my car is the 102hp engine from the DX. When it wears out, I plan to install the D15Z1 engine used in the VX, which should greatly improve my highway mileage since, with my car's low drag, I could remain in lean burn on a flat road up to 90mph.
aerocivic.com
Old 04-22-2009, 05:04 PM   #238 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
rkcarguy: Basjoos wouldn't benefit much from any engine swap since he hardly uses it
eキcoキmodキding: the art of turning vehicles into what they should be
Piwoslaw's Peugeot 307sw modding thread
Old 04-22-2009, 05:26 PM   #239 (permalink)
I disagree. Especially if he switched to the 3-stage VTEC which has lean burn and also 130HP hi-cam, he could see better MPG-over 10%+ possibly, and have more power on tap if you want it.
At a 95mpg best without a VTEC-E, a lean burn engine could push this car into the record books.
Old 04-22-2009, 07:34 PM   #240 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Civic LX
90 day: 40.53 mpg (US)
I believe he's in this for savings and wants any additions to pay for themselves in short order, and that's why he isn't planning on getting a lean-burn engine until his current one gives out.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
Posted By For Type Date
Aerocivic - how to drop your Cd from 0.31 to 0.17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 01-23-2012 08:53 AM
Week of November 21st - November 27th, 2011 (Nat Avg $3.37) - Page 4 - CleanMPG Forums This thread Refback 11-25-2011 11:27 AM
Overdrive.fiョ | N艙t viesti - Pisaralla pisimmlle -jenkki This thread Refback 10-12-2011 03:58 AM
Anyone have a 1.7 cdti ? • Honda Civic Forum This thread Refback 10-05-2011 07:07 PM
Improving MPG - Page 2 This thread Refback 10-03-2011 11:09 AM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Chevrolet Impala SS Forum : Chevy Impala SS Forums This thread Refback 09-23-2011 01:53 AM
Slippery Eg Civic | RMS Forum This thread Refback 09-15-2011 04:56 PM
Fuel vapour carburetor ?? Any thoughts? This thread Refback 09-07-2011 03:38 AM
Ecotuning This thread Refback 08-30-2011 04:12 PM
DIY metro aero body This thread Refback 08-09-2011 10:17 PM
Outside Rear View Mirror - Red Pepper Racing This thread Refback 07-27-2011 11:00 PM
Aerocivic How To Drop Your Cd From 031 To 017 Page 41 Fuel This thread Refback 07-24-2011 11:12 AM
www.neons.org • View topic - My ecomodded neon. Tire spats & mini folding mirror install. This thread Refback 06-26-2011 10:16 AM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-22-2011 02:09 PM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-17-2011 06:46 PM
???????????????????????????????????????? ?????? - ??????Days This thread Refback 05-15-2011 06:05 AM
、ネ、テ、ニ、箍ツチエ、ハ・ユ・ァ・・タ。シ・゚・鬘シシヨ、ャタ萠ヌタ」チー。「・ノ・「・゚・鬘シ、ネ、ォエ、ハ、、、タ、ア、ヌ、ケ、陦ト。ト。ェ ・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 05-11-2011 10:13 AM
archives for 07/2009 This thread Refback 04-16-2011 04:56 PM
・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 04-10-2011 10:15 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 04-07-2011 01:10 AM
???????????????????????????????????????? : ?????? This thread Refback 04-01-2011 06:51 AM
Your answer to rising gas prices! This thread Refback 03-19-2011 03:45 PM
Project MMPG ~Slow build thread This thread Refback 03-07-2011 08:05 PM
I'm Dac Biet This thread Refback 03-07-2011 06:19 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 03-06-2011 06:43 AM
Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 02-24-2011 05:49 PM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-09-2011 12:35 AM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-08-2011 11:01 PM
Tobias Laboratories サ 1989 Geo Metro This thread Refback 02-04-2011 06:43 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 01-30-2011 07:41 PM
Motorbyte i moppebil - generatorfrgor This thread Refback 01-08-2011 07:09 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 01-05-2011 04:37 AM
The Nissan Path :: View topic - What octane gas do you use? This thread Refback 12-27-2010 11:43 PM
www.neons.org • View topic - ...AERODYNAMIC FAIL! This thread Refback 12-15-2010 12:19 PM
blekko | honda insight mpg at 70mph This thread Refback 11-14-2010 04:16 PM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-14-2010 06:37 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 10:18 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 07:24 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 04:58 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:56 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:53 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:40 AM
ュサエ莢Qスラーマ Discuss.com.hk This thread Refback 11-13-2010 12:40 AM
forum.group44.de • Thema anzeigen - Surftipp fr Aerodynamik- & Sparfreaks This thread Refback 10-18-2010 11:54 AM
XINeons.com View topic - custom bumper idea This thread Refback 10-08-2010 11:07 PM
Improving MPG This thread Refback 09-15-2010 01:19 AM
The 100 mpg carb - Does it really exist? This thread Refback 08-11-2010 11:16 PM
So, we haven't bashed Prius' in a while ... - LS1GTO.com Forums This thread Refback 07-27-2010 01:27 AM
1962 Mustang images & 1962 Mustang stock photos at HealthHaven.com This thread Refback 07-20-2010 10:12 PM
New transport secretary = idiot Singletrack Forum This thread Refback 06-02-2010 05:06 AM
AlterSlash ~ the unofficial SlashDot digest This thread Refback 05-31-2010 06:29 PM
www.neons.org • View topic - My ecomodded neon. Thinking about an aero front bumper... This thread Refback 05-31-2010 06:24 PM
Slashdot | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:44 AM
Slashdot Comments | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:35 AM
Slashdot Hardware Story | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 08:44 AM
新型プリウスで東京〜鹿児島〜熊本の無給油燃費記録に挑戦 This thread Refback 05-27-2010 08:10 AM
Improving MPG - Page 2 - Ranger Power Sports Forum This thread Refback 05-26-2010 12:57 AM
Your answer to rising gas prices! This thread Refback 05-11-2010 01:40 PM
Project Super zuinig... - Afdrukversie This thread Refback 04-04-2010 12:12 PM
L'aerodinamica della Civic This thread Refback 03-10-2010 07:17 PM
Wykop.pl - Ekonomiczny Civic spala tylko 2,5l litra benzyny na 100km - Powi?zane This thread Refback 02-22-2010 06:57 PM
www.HondaTuning.lt - View topic - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 02-21-2010 12:08 PM
I have yet to see a thread address this - TDIClub Forums This thread Refback 02-19-2010 01:55 PM
Aerodynamics (Project KITT) This thread Refback 02-09-2010 10:08 PM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Impala SS Forum This thread Refback 02-09-2010 07:55 PM
Homesteading Reviews This thread Refback 02-07-2010 11:25 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co mo?emy poprawi?? This thread Refback 02-05-2010 04:34 PM
【燃費】まじめに燃費向上を語り合うスレ 37km/L This thread Refback 02-04-2010 12:28 PM
I have yet to see a thread address this - Page 2 - TDIClub Forums This thread Refback 01-20-2010 07:23 AM
electroauto.ru :: ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 01-16-2010 08:05 AM
I have yet to see a thread address this - TDIClub Forums This thread Refback 01-10-2010 03:37 PM
Do it yourself aero modification This thread Refback 01-02-2010 02:55 PM
??????[??]?????????????????? This thread Refback 12-14-2009 04:23 AM
www.neons.org • View topic - My ecomodded neon. Insight tire teaser! 11-21-09 This thread Refback 11-23-2009 11:28 PM
Tailboxes work for everyone - 'BentRider Online Forums This thread Refback 11-18-2009 03:00 PM
Untitled document This thread Refback 11-17-2009 08:04 AM
Noul Logan Renault eco2, cu 3,8% consum - DaciaClub - Forum Dacia This thread Refback 11-12-2009 04:45 AM
electroauto.ru • ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 11-10-2009 11:41 AM
菴守雋サ縺ァ襍ー繧後k繧医≧縺ォ謾ケ騾縺輔l縺溘お繧「繝ュ繧キ繝薙ャ繧ッ縺ョ蜀咏悄 - darkwater 縲 縺ソ繧薙き繝ゥ 縲 繝悶Ο繧ー This thread Refback 11-04-2009 11:34 AM
Motorbyte i moppebil - generatorfr虍or This thread Refback 10-06-2009 01:23 PM
Rad blind experiment - MBClub UK Forums This thread Refback 09-25-2009 03:42 AM
www.hondatuning.lt :: Perirti tem - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 09-03-2009 10:48 AM
www.neons.org • View topic - My hypermiler. Rapid acceleration is better! This thread Refback 09-01-2009 02:56 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 08:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 01:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 09:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
