Old 12-29-2007, 03:03 PM   #31 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
Originally Posted by martae View Post
Great job Basjoos, but why didn't you start with a civic VX instead of a CX ? It was the high mileage model. Feather light aluminum wheels. Wider ratio transmission with a higher final drive ratio (2000 rpm at 60 mph). Variable valve timing with a twist. In this engine only one intake valve opens below 2500 rpm. Since there is only one intake valve open more of the pressure drop between the atmosphere and the cylinder is across the valve rather than the throttle plate. This gives a more turbulent fuel air mixture which allows a leaner fuel/air charge, greater torque at low engine speed, and no predetonation . The use of a very sensitive oxygen sensor (unique to the VX) allows more precise control of the FA mixture making a very low idle possible. On a warm day mine idles at about 500 rpm. The practical effect of these engine tweaks is high torque at low RPM sort of like a diesel. As I'm sure you guys know, the great weakness of the Otto cycle (the spark igniton gasoline engine is an Otto cycle engine) are the large pumping losses at part load caused by sucking the FA charge past the throttle plate. The ability of this engine to deliver good torque at low RPM (and thus lower pumping losses) is the secret to the high fuel economy this car delivers. The CX and the VX share the same body, but the CX is listed at EPA 42/46 and the VX at 47/56. The VX also offers higher power since the engine has the same displacement, but four valves per cylinder (92 vs 70). I bought mine new in 1992, have put 208 thousand miles on it and still average 45 mpg to work and around town. When the car was new 52 or 53 mpg was not unusual on a long road trip. The fact Honda could do this with the technology of 15 years ago shows what a bunch of liars the auto companies are when they squeal about a 35 mpg average fuel economy rule.
I started with a CX (which I had bought new in 92) rather than a VX because that was the car I was driving at the time I decided to start aero modding my car. The CX and VX share the same transmission. The main differences being the in engine,, lighter wheels, some additional interior features in the VX (the CX is the bare bones Civic model) and some underbody aero to slightly reduce the Cd of the VX. The VX and CX have the same weight. When new, my CX typically gave me 51mpg on the highway in the summer (44mpg highway in the winter) and 38mpg was the worst I ever got with it (in snow driving and winter tires). Interestingly, when I installed a DX engine at 245,000 miles (but kept the same transmission), the mileage remained the same, but my 0 to 60 times dropped to 10 sec.
aerocivic.com
Old 12-29-2007, 06:20 PM   #32 (permalink)
Dennis the Menace
Exhaust / Coolant / Air intake
You were talking about changing the intake for the coolant to vary with need of cooling, have you thought of a heat exchanger for the intake air for combustion or for that matter from you exhaust, routing the cool air through the rad, then to an exhaust heat exchanger then to the engine, in effect reclaiming the heat that would have been waisted... there is an interesting article in Popular Science about using the heat to produce steam in the engine...
http://www.popsci.com/popsci/technol...cbccdrcrd.html
Old 12-29-2007, 09:04 PM   #33 (permalink)
basjoos's Avatar
I figure my intake air gets warm enough just from the tightly cowled engine compartment (its completely underpanelled, with a mostly blocked grill and the hot radiator air exhausted out through the front wheel wells). They've had some discussions of warm air intake temps at Gassavers and concluded that although warm intake air improves mileage (at the expense of power, you are in effect driving a less powerful engine with a more open throttle plate with reduced pumping losses), but if the intake air gets too hot, it has detrimental effects on mileage (perhaps because the engine ECU isn't programmed to handle intake temps that are way above what its programmers thought it might ever experience).
aerocivic.com
Old 12-30-2007, 12:52 PM   #34 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
70 years ago... the aero Model T
FYI - for those interested in the subject of radical aero mods, you might want to check the thread about Harry Stevinson, my friend's dad. He was bitten by the same bug that got basjoos ... 70 years ago:
Old 12-30-2007, 06:40 PM   #35 (permalink)
basjoos's Avatar
All of this recent activity used up all of this month's bandwidth on my free Photobucket account. Next month's bandwidth allotment will become available on Jan 2.
aerocivic.com
Old 12-30-2007, 07:04 PM   #36 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
If you want to send me the pictures I can host them on the ecomodder server for you.
Old 12-31-2007, 12:43 PM   #37 (permalink)
The images can also be seen at this site: http://www.cleanmpg.com/photos/showg...=500&ppuser=18
Old 01-01-2008, 01:20 PM   #38 (permalink)
I've posted the images on the Ecomodder server - they're all visible now. No more Photobucket bandwidth problems.
Old 01-01-2008, 04:35 PM   #39 (permalink)
If we get the aftermarket body mod industry to start thinking ecomodding, changes like the ones Basjoos has made might be accomplished in a weekend. See: http://www.bodykits.com/store/home.php?cat=1281 as an example.
Old 01-01-2008, 04:38 PM   #40 (permalink)
Dartmouth 2010
SVOboy's Avatar
I do believe newton has had that thought (of making aero body kits for ecomodders), and I definately think it's worth a go. If I knew anything about molding and all that jazz I might play with it myself...
If someone made a boattail for a prius I'm sure that would get the business going.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
Posted By For Type Date
Aerocivic - how to drop your Cd from 0.31 to 0.17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 01-23-2012 08:53 AM
Week of November 21st - November 27th, 2011 (Nat Avg $3.37) - Page 4 - CleanMPG Forums This thread Refback 11-25-2011 11:27 AM
Overdrive.fiョ | N艙t viesti - Pisaralla pisimmlle -jenkki This thread Refback 10-12-2011 03:58 AM
Anyone have a 1.7 cdti ? • Honda Civic Forum This thread Refback 10-05-2011 07:07 PM
Improving MPG - Page 2 This thread Refback 10-03-2011 11:09 AM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Chevrolet Impala SS Forum : Chevy Impala SS Forums This thread Refback 09-23-2011 01:53 AM
Slippery Eg Civic | RMS Forum This thread Refback 09-15-2011 04:56 PM
Fuel vapour carburetor ?? Any thoughts? This thread Refback 09-07-2011 03:38 AM
Ecotuning This thread Refback 08-30-2011 04:12 PM
DIY metro aero body This thread Refback 08-09-2011 10:17 PM
Outside Rear View Mirror - Red Pepper Racing This thread Refback 07-27-2011 11:00 PM
Aerocivic How To Drop Your Cd From 031 To 017 Page 41 Fuel This thread Refback 07-24-2011 11:12 AM
www.neons.org • View topic - My ecomodded neon. Tire spats & mini folding mirror install. This thread Refback 06-26-2011 10:16 AM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-22-2011 02:09 PM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-17-2011 06:46 PM
???????????????????????????????????????? ?????? - ??????Days This thread Refback 05-15-2011 06:05 AM
、ネ、テ、ニ、箍ツチエ、ハ・ユ・ァ・・タ。シ・゚・鬘シシヨ、ャタ萠ヌタ」チー。「・ノ・「・゚・鬘シ、ネ、ォエ、ハ、、、タ、ア、ヌ、ケ、陦ト。ト。ェ ・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 05-11-2011 10:13 AM
archives for 07/2009 This thread Refback 04-16-2011 04:56 PM
・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 04-10-2011 10:15 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 04-07-2011 01:10 AM
???????????????????????????????????????? : ?????? This thread Refback 04-01-2011 06:51 AM
Your answer to rising gas prices! This thread Refback 03-19-2011 03:45 PM
Project MMPG ~Slow build thread This thread Refback 03-07-2011 08:05 PM
I'm Dac Biet This thread Refback 03-07-2011 06:19 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 03-06-2011 06:43 AM
Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 02-24-2011 05:49 PM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-09-2011 12:35 AM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-08-2011 11:01 PM
Tobias Laboratories サ 1989 Geo Metro This thread Refback 02-04-2011 06:43 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 01-30-2011 07:41 PM
Motorbyte i moppebil - generatorfrgor This thread Refback 01-08-2011 07:09 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 01-05-2011 04:37 AM
The Nissan Path :: View topic - What octane gas do you use? This thread Refback 12-27-2010 11:43 PM
www.neons.org • View topic - ...AERODYNAMIC FAIL! This thread Refback 12-15-2010 12:19 PM
blekko | honda insight mpg at 70mph This thread Refback 11-14-2010 04:16 PM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-14-2010 06:37 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 10:18 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 07:24 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 04:58 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:56 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:53 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:40 AM
ュサエ莢Qスラーマ Discuss.com.hk This thread Refback 11-13-2010 12:40 AM
forum.group44.de • Thema anzeigen - Surftipp fr Aerodynamik- & Sparfreaks This thread Refback 10-18-2010 11:54 AM
XINeons.com View topic - custom bumper idea This thread Refback 10-08-2010 11:07 PM
Improving MPG This thread Refback 09-15-2010 01:19 AM
The 100 mpg carb - Does it really exist? This thread Refback 08-11-2010 11:16 PM
So, we haven't bashed Prius' in a while ... - LS1GTO.com Forums This thread Refback 07-27-2010 01:27 AM
1962 Mustang images & 1962 Mustang stock photos at HealthHaven.com This thread Refback 07-20-2010 10:12 PM
New transport secretary = idiot Singletrack Forum This thread Refback 06-02-2010 05:06 AM
AlterSlash ~ the unofficial SlashDot digest This thread Refback 05-31-2010 06:29 PM
www.neons.org • View topic - My ecomodded neon. Thinking about an aero front bumper... This thread Refback 05-31-2010 06:24 PM
Slashdot | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:44 AM
Slashdot Comments | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:35 AM
Slashdot Hardware Story | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 08:44 AM
新型プリウスで東京〜鹿児島〜熊本の無給油燃費記録に挑戦 This thread Refback 05-27-2010 08:10 AM
Improving MPG - Page 2 - Ranger Power Sports Forum This thread Refback 05-26-2010 12:57 AM
Your answer to rising gas prices! This thread Refback 05-11-2010 01:40 PM
Project Super zuinig... - Afdrukversie This thread Refback 04-04-2010 12:12 PM
L'aerodinamica della Civic This thread Refback 03-10-2010 07:17 PM
Wykop.pl - Ekonomiczny Civic spala tylko 2,5l litra benzyny na 100km - Powi?zane This thread Refback 02-22-2010 06:57 PM
www.HondaTuning.lt - View topic - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 02-21-2010 12:08 PM
I have yet to see a thread address this - TDIClub Forums This thread Refback 02-19-2010 01:55 PM
Aerodynamics (Project KITT) This thread Refback 02-09-2010 10:08 PM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Impala SS Forum This thread Refback 02-09-2010 07:55 PM
Homesteading Reviews This thread Refback 02-07-2010 11:25 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co mo?emy poprawi?? This thread Refback 02-05-2010 04:34 PM
【燃費】まじめに燃費向上を語り合うスレ 37km/L This thread Refback 02-04-2010 12:28 PM
I have yet to see a thread address this - Page 2 - TDIClub Forums This thread Refback 01-20-2010 07:23 AM
electroauto.ru :: ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 01-16-2010 08:05 AM
I have yet to see a thread address this - TDIClub Forums This thread Refback 01-10-2010 03:37 PM
Do it yourself aero modification This thread Refback 01-02-2010 02:55 PM
??????[??]?????????????????? This thread Refback 12-14-2009 04:23 AM
www.neons.org • View topic - My ecomodded neon. Insight tire teaser! 11-21-09 This thread Refback 11-23-2009 11:28 PM
Tailboxes work for everyone - 'BentRider Online Forums This thread Refback 11-18-2009 03:00 PM
Untitled document This thread Refback 11-17-2009 08:04 AM
Noul Logan Renault eco2, cu 3,8% consum - DaciaClub - Forum Dacia This thread Refback 11-12-2009 04:45 AM
electroauto.ru • ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 11-10-2009 11:41 AM
菴守雋サ縺ァ襍ー繧後k繧医≧縺ォ謾ケ騾縺輔l縺溘お繧「繝ュ繧キ繝薙ャ繧ッ縺ョ蜀咏悄 - darkwater 縲 縺ソ繧薙き繝ゥ 縲 繝悶Ο繧ー This thread Refback 11-04-2009 11:34 AM
Motorbyte i moppebil - generatorfr虍or This thread Refback 10-06-2009 01:23 PM
Rad blind experiment - MBClub UK Forums This thread Refback 09-25-2009 03:42 AM
www.hondatuning.lt :: Perirti tem - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 09-03-2009 10:48 AM
www.neons.org • View topic - My hypermiler. Rapid acceleration is better! This thread Refback 09-01-2009 02:56 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 08:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 01:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 09:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
