Old 07-18-2010, 06:59 PM   #421 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
If cold is a concern, there are plenty of heater cores available, and you can leave the grill closed longer if you use coolant to heat the cab. I wouldn't turn my nose up at reusing any extra heat if it's extra cold. given how prevalent liquid cooled cars with heat are, that's easily accomplished.
Old 07-25-2010, 02:49 PM   #422 (permalink)
- - '010 Prius III w/Navi
Hi All,
All I can say, is a variable cooling intake is very much needed. We have had 20 to 30 mph steady winds out of the direction my home trip as the crow-flies is in. With Hypermiling technique driving my Prius, the car does not get into a warmed up state sufficient to ensure an engine shut down below 35 mpg, until like 3/4's the way into the trip. But Friday, its like the hottest day of the year here (95 F with 105 F THI), BUT with 30 mph gusting to 40. The car never got fully warmed up over that 1 hour / 23 mile trip! The wind was making the air speeds up to 80 mpg, and with pulse and glide, the car just did not reach the temps where it would shut down the engine.
Old 08-06-2010, 02:59 AM   #423 (permalink)
Beater - '07 Aveo
90 day: 27.11 mpg (US)
Excellent thread!
Its now 1am and i've just read every page. Thanks for the detailed log of mods and effects. I'll spend the next few days day dreaming and taking all i've read.
Thanks!
Old 08-22-2010, 10:56 PM   #424 (permalink)
I have to start over?
Big inefficient truck - '94 Ram 2500
90 day: 18.43 mpg (US)
Honda Civic - '84 Civic DX Hatchback
Originally Posted by JJMunoz View Post
I was thinking of using the styrofoam crash protection that's comes under the front bumper cover on the outside...
Originally Posted by JimIsbell View Post
Yes, I agree with you about pretty....but my wife DOESNT! But your mods could be prettied up and still work, maybe even better, but that might take a lot of work that was better spent on research.
How's this for foam, any aero shape you want, AND PRETTY? Try covering your car in expanding polyurethane foam, then shaving down to the right shape and painting. (Jim, looks like you and I were onto the same idea)
Originally Posted by basjoos View Post
It probably would get better mileage with more ground clearance, but its not as easy to raise an independent suspension as it is a truck with solid axles. It would also raise the center of gravity and make it more tippy in a turn, reducing safety.
You could always put tires on that are a little bigger than stock. Get a few CM extra, and taller gear ratios to boot. Not sure if the extra weight of the bigger tire would offset any gain, though. Prolly not
Basjoos, I have a question about the construction you used. It looks like you used a lot of coroplast, then aluminum sheeting, held on with rivets or screws, but what is that glue/filler type stuff you used on the coroplast? I guess it is the same stuff you used in the body gaps?
Old 08-23-2010, 08:43 AM   #425 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
At this point, the only Coroplast is on the belly pan, side skirts, and front wheel air splitters where I need the flexibility to pop back from impacts that aluminum sheet doesn't have. The filler/seal stuff is mostly white exterior grade latex caulk from Lowe's, although I did use epoxy putty on some locations where I needed thicker layers than could be done with caulk.
aerocivic.com
Old 08-23-2010, 06:16 PM   #426 (permalink)
Basjoos, looks like they found you! Thanks for the info, btw
On a serious note, this can tell you what people think of extreme ecomodding:
Can A Honda Civic Even GO 88mph? - That Will Buff Out - Funny Car Photos
Old 08-23-2010, 08:51 PM   #427 (permalink)
basjoos's Avatar
That type of stuff doesn't bother me, some people think my car looks weird, others think it looks cool. I've noticed more "performance" car buffs in the former group because my car isn't a NASCAR clone like their idealized car (I guess most don't follow Speedweek at Bonneville) I've noticed more kids and non-car enthusiasts in the latter group since they don't have a strong pre-conceived idea of what a car is "suppose" to look like and can evaluate it purely on its "neat" factor. I get more thumbs up than thumbs down on the road and of course lots of pictures taken. But until they can point to a "normal" looking car that can match my car's combination of mileage and high speed performance, the detractors have no leg to stand on.
At 88mph I have about the same wind load that I used to have at 65mph in my pre-aeromod days and that wind load is just barely beginning to make its presence known at 88mph. At that speed on flat ground I am still well within the lean burn performance window and getting mileage in the low 70's.
Old 08-24-2010, 10:46 AM   #428 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 72.37 mpg (US)
Yeah, those NASCAR vehicles are specifically designed to be less than ideal for drag. Some of it is for downforce, some is just to handicap the race. Average Joe doesn't see that, though. He sees 180 mph and thinks that car must be the best way to do it, not realizing it's a crude brute-force approach.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 09-21-2010, 11:53 PM   #429 (permalink)
Crusty - '91 Civic Sedan LX
90 day: 38.93 mpg (US)
Nascar is effing ghey.
Old 10-10-2010, 07:08 AM   #430 (permalink)
Tiny - '90 CRX HF
Last 3: 55.97 mpg (US)
Can you please tell me how you came across that superMID?
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
Posted By For Type Date
Aerocivic - how to drop your Cd from 0.31 to 0.17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 01-23-2012 08:53 AM
Week of November 21st - November 27th, 2011 (Nat Avg $3.37) - Page 4 - CleanMPG Forums This thread Refback 11-25-2011 11:27 AM
Overdrive.fi | Nyt viesti - Pisaralla pisimmlle -jenkki This thread Refback 10-12-2011 03:58 AM
Anyone have a 1.7 cdti ? • Honda Civic Forum This thread Refback 10-05-2011 07:07 PM
Improving MPG - Page 2 This thread Refback 10-03-2011 11:09 AM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Chevrolet Impala SS Forum : Chevy Impala SS Forums This thread Refback 09-23-2011 01:53 AM
Slippery Eg Civic | RMS Forum This thread Refback 09-15-2011 04:56 PM
Fuel vapour carburetor ?? Any thoughts? This thread Refback 09-07-2011 03:38 AM
Ecotuning This thread Refback 08-30-2011 04:12 PM
DIY metro aero body This thread Refback 08-09-2011 10:17 PM
Outside Rear View Mirror - Red Pepper Racing This thread Refback 07-27-2011 11:00 PM
Aerocivic How To Drop Your Cd From 031 To 017 Page 41 Fuel This thread Refback 07-24-2011 11:12 AM
www.neons.org • View topic - My ecomodded neon. Tire spats & mini folding mirror install. This thread Refback 06-26-2011 10:16 AM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-22-2011 02:09 PM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-17-2011 06:46 PM
???????????????????????????????????????? ?????? - ??????Days This thread Refback 05-15-2011 06:05 AM
ȤäƤʥեߥ顼֤ɥߥ顼ȤʤǤġġ ٥2chư֥˥塼 This thread Refback 05-11-2011 10:13 AM
archives for 07/2009 This thread Refback 04-16-2011 04:56 PM
٥2chư֥˥塼 This thread Refback 04-10-2011 10:15 AM
ƂĂSȃtF_[~[ԂŐOAhA~[ƂȂłccI This thread Refback 04-07-2011 01:10 AM
???????????????????????????????????????? : ?????? This thread Refback 04-01-2011 06:51 AM
Your answer to rising gas prices! This thread Refback 03-19-2011 03:45 PM
Project MMPG ~Slow build thread This thread Refback 03-07-2011 08:05 PM
I'm Dac Biet This thread Refback 03-07-2011 06:19 AM
ƂĂSȃtF_[~[ԂŐOAhA~[ƂȂłccI This thread Refback 03-06-2011 06:43 AM
Zobacz temat - Aerodynamika Corsy - co moemy poprawi? This thread Refback 02-24-2011 05:49 PM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-09-2011 12:35 AM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-08-2011 11:01 PM
Tobias Laboratories 1989 Geo Metro This thread Refback 02-04-2011 06:43 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 01-30-2011 07:41 PM
Motorbyte i moppebil - generatorfrgor This thread Refback 01-08-2011 07:09 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co moemy poprawi? This thread Refback 01-05-2011 04:37 AM
The Nissan Path :: View topic - What octane gas do you use? This thread Refback 12-27-2010 11:43 PM
www.neons.org • View topic - ...AERODYNAMIC FAIL! This thread Refback 12-15-2010 12:19 PM
blekko | honda insight mpg at 70mph This thread Refback 11-14-2010 04:16 PM
EG Civic ], Cd 0.34 0.17 - T - Qװ discuss.com.hk - @ӭuo@ӭQװ This thread Refback 11-14-2010 06:37 AM
EG Civic ], Cd 0.34 0.17 - T - Qװ discuss.com.hk - @ӭuo@ӭQװ This thread Refback 11-13-2010 10:18 AM
EG Civic ], Cd 0.34 0.17 - T - Qװ discuss.com.hk - @ӭuo@ӭQװ This thread Refback 11-13-2010 07:24 AM
EG Civic ], Cd 0.34 0.17 - T - Qװ discuss.com.hk - @ӭuo@ӭQװ This thread Refback 11-13-2010 04:58 AM
EG Civic ], Cd 0.34 0.17 - T - Qװ discuss.com.hk - @ӭuo@ӭQװ This thread Refback 11-13-2010 12:56 AM
EG Civic ], Cd 0.34 0.17 - T - Qװ discuss.com.hk - @ӭuo@ӭQװ This thread Refback 11-13-2010 12:53 AM
EG Civic ], Cd 0.34 0.17 - T - Qװ discuss.com.hk - @ӭuo@ӭQװ This thread Refback 11-13-2010 12:40 AM
Qװ Discuss.com.hk This thread Refback 11-13-2010 12:40 AM
forum.group44.de • Thema anzeigen - Surftipp fr Aerodynamik- & Sparfreaks This thread Refback 10-18-2010 11:54 AM
XINeons.com View topic - custom bumper idea This thread Refback 10-08-2010 11:07 PM
Improving MPG This thread Refback 09-15-2010 01:19 AM
The 100 mpg carb - Does it really exist? This thread Refback 08-11-2010 11:16 PM
So, we haven't bashed Prius' in a while ... - LS1GTO.com Forums This thread Refback 07-27-2010 01:27 AM
1962 Mustang images & 1962 Mustang stock photos at HealthHaven.com This thread Refback 07-20-2010 10:12 PM
New transport secretary = idiot Singletrack Forum This thread Refback 06-02-2010 05:06 AM
AlterSlash ~ the unofficial SlashDot digest This thread Refback 05-31-2010 06:29 PM
www.neons.org • View topic - My ecomodded neon. Thinking about an aero front bumper... This thread Refback 05-31-2010 06:24 PM
Slashdot | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:44 AM
Slashdot Comments | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:35 AM
Slashdot Hardware Story | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 08:44 AM
V^vEXœ``F{̖RL^ɒ This thread Refback 05-27-2010 08:10 AM
Improving MPG - Page 2 - Ranger Power Sports Forum This thread Refback 05-26-2010 12:57 AM
Your answer to rising gas prices! This thread Refback 05-11-2010 01:40 PM
Project Super zuinig... - Afdrukversie This thread Refback 04-04-2010 12:12 PM
L'aerodinamica della Civic This thread Refback 03-10-2010 07:17 PM
Wykop.pl - Ekonomiczny Civic spala tylko 2,5l litra benzyny na 100km - Powi?zane This thread Refback 02-22-2010 06:57 PM
www.HondaTuning.lt - View topic - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 02-21-2010 12:08 PM
I have yet to see a thread address this - TDIClub Forums This thread Refback 02-19-2010 01:55 PM
Aerodynamics (Project KITT) This thread Refback 02-09-2010 10:08 PM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Impala SS Forum This thread Refback 02-09-2010 07:55 PM
Homesteading Reviews This thread Refback 02-07-2010 11:25 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co mo?emy poprawi?? This thread Refback 02-05-2010 04:34 PM
yRz܂߂ɔR荇X 37km/L This thread Refback 02-04-2010 12:28 PM
I have yet to see a thread address this - Page 2 - TDIClub Forums This thread Refback 01-20-2010 07:23 AM
electroauto.ru :: ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 01-16-2010 08:05 AM
I have yet to see a thread address this - TDIClub Forums This thread Refback 01-10-2010 03:37 PM
Do it yourself aero modification This thread Refback 01-02-2010 02:55 PM
??????[??]?????????????????? This thread Refback 12-14-2009 04:23 AM
www.neons.org • View topic - My ecomodded neon. Insight tire teaser! 11-21-09 This thread Refback 11-23-2009 11:28 PM
Tailboxes work for everyone - 'BentRider Online Forums This thread Refback 11-18-2009 03:00 PM
Untitled document This thread Refback 11-17-2009 08:04 AM
Noul Logan Renault eco2, cu 3,8% consum - DaciaClub - Forum Dacia This thread Refback 11-12-2009 04:45 AM
electroauto.ru • ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 11-10-2009 11:41 AM
低燃費で走れるように改造されたエアロシビックの写真 - darkwater 【 みんカラ 】 ブログ This thread Refback 11-04-2009 11:34 AM
Motorbyte i moppebil - generatorfrgor This thread Refback 10-06-2009 01:23 PM
Rad blind experiment - MBClub UK Forums This thread Refback 09-25-2009 03:42 AM
www.hondatuning.lt :: Perirti tem - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 09-03-2009 10:48 AM
www.neons.org • View topic - My hypermiler. Rapid acceleration is better! This thread Refback 09-01-2009 02:56 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 08:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 01:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 09:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
