Old 01-01-2008, 04:55 PM   #41 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Originally Posted by SVOboy View Post
I do believe newton has had that thought (of making aero body kits for ecomodders), and I definitely think it's worth a go. If I knew anything about molding and all that jazz I might play with it myself...
If someone made a boattail for a prius I'm sure that would get the business going.
Molding isn't too hard - just requires several pretty pennies of start up capitol
Challenge me, or correct me, but don't ask me to die quietly.
Old 01-02-2008, 09:20 PM   #42 (permalink)
UfoTofU's Avatar
Looks good basjoos!
I found this via Hack-A-Day actually.
Old 01-05-2008, 10:39 PM   #43 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
Originally Posted by Spyral View Post
Wow, do you think I should do this to my GTO? I get about 26mpg on the highway and about 12mpg around town. Depending if I am on the gas or not. When I activate the nitrous oxide system I get even worse gas mileage. However, the car is very fast. I have no catalytic converters on it either.
The car looks great!
Cd reduction would work to improve the high speed performance of any car and is what they do on the Bonneville Salt Flats to increase the speeds of their speed record cars. Since aerodynamic drag is the dominant load factor at higher speeds, the faster you go, the more you'll notice the effects of a low Cd, reducing the amount of power you need to travel at that speed and in effect acting as the equivalent of a horsepower boost at the higher speed. As far as fuel efficiency goes, a low Cd extends the range of speeds where you can still get good fuel economy into the higher speed brackets and a low Cd car will get better fuel economy than an otherwise identical high Cd car at any speed above 30mph, the difference becoming more and more noticable the faster you travel.
aerocivic.com
Old 01-08-2008, 07:41 PM   #44 (permalink)
basjoos's Avatar
Based on what I saw in the road salt deposition patterns, the largest recirculating eddys remaining are those produced downwind of each rear wheel,so I built and installed a mini boattail behind each rear wheel.
aerocivic.com
Old 01-08-2008, 11:51 PM   #45 (permalink)
Basjoos,
You are an inspiration to us all!
Old 01-09-2008, 12:06 AM   #46 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
Is there a deflector on the front of the rear wheels?
My Convertible Metro XFI Plug in Hybrid Project build log
Old 01-09-2008, 12:34 AM   #47 (permalink)
Basjoos - could you do some pics of how the radiator exit air leaves via the wheel wells? And how efficient is this (relatively) to bonnet vents? I know many of the recent Porsche 911 models vent the rad air into the rear wheel wells, but they appear to use shaped spokes on the rear wheels to act as a fan.
Michael
'71 240Z RB20DET
'99 Toyota Echo (Yaris) sedan.
Old 01-09-2008, 02:20 PM   #48 (permalink)
No, better:
Originally Posted by basjoos View Post
there are 2 side skirts on each side, one even with the inner edge of the tires, the other even with the outer edge of the tires
Old 01-09-2008, 09:51 PM   #49 (permalink)
basjoos's Avatar
The radiator air exits through the stock openings to the front wheel wells, which have the OEM wheels. The advantage of this method over bonnet vents is that I am dumping my radiator exhaust into an area that is already turbulent, so it isn't adding to the total amount of turbulent air created by the vehicle. But the air exhausted from bonnet vents, depending on how it is handled, could add turbulence to the car's airflow as it merges with it.
There are deflectors in front of the rear wheels in between the two side skirts. I started out with a wheel spoiler in front of each wheel using the spoiler design found on many hondas and toyotas that deflects the air downward in front of the wheel. I later replaced the front wheel spoiler with the current air splitter and added the side skirts, but left the rear spoilers in place to deflect any air that got up inside the side skirts before it encounters the rear wheel.
aerocivic.com
Old 01-10-2008, 12:40 AM   #50 (permalink)
The radiator air exits through the stock openings to the front wheel wells, which have the OEM wheels. The advantage of this method over bonnet vents is that I am dumping my radiator exhaust into an area that is already turbulent, so it isn't adding to the total amount of turbulent air created by the vehicle. But the air exhausted from bonnet vents, depending on how it is handled, could add turbulence to the car's airflow as it merges with it."
So, is the air in the wheel wells at low pressure? That seems to be a contentious issue on the net, seeing as how many race cars have vents over/behind the front wheels to vent air from the wheel wells (although on some drag VW Beetles they put vents over/behind the wheels to stop the fenders from generating lift). I know the air in front of the tire is at high pressure, but I would assume the air behind the tire is at low pressure.
I'm trying to solve a cooling issue with my car (1971 Datsun 240Z with intercooled 6cyl 2lt turbo) due to horrific airflow issues with the engine bay. I can (and will) reduce the air entry through the radiator support panel, but I'm trying to work out how best to get the air out from the engine bay. The air past the turbo gets to ~ 230C, and heats the firewall & trans tunnel to ~ 70C which makes it rather uncomfortable in Summer.
I could use the trans tunnel as a duct to the rear wheel wells (undertray and with insulation on the tunnel to try and keep the heat out of the car) - not sure how well this would work. Or possibly duct from the engine bay to the front wheel wells (through or under the inner guards) with vents in the guards behind the wheels.
I'm also looked at the 2lt Super Touring cars - the ones I looked at (BMW RWD and some FWD's) had the air through two small radiators and then the outlet air is ducted to vents in the ends of the front spoiler (side of the body) ahead of the front wheels.
Michael
'71 240Z RB20DET
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
Posted By For Type Date
Aerocivic - how to drop your Cd from 0.31 to 0.17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 01-23-2012 08:53 AM
Week of November 21st - November 27th, 2011 (Nat Avg $3.37) - Page 4 - CleanMPG Forums This thread Refback 11-25-2011 11:27 AM
Overdrive.fiョ | N艙t viesti - Pisaralla pisimmlle -jenkki This thread Refback 10-12-2011 03:58 AM
Anyone have a 1.7 cdti ? • Honda Civic Forum This thread Refback 10-05-2011 07:07 PM
Improving MPG - Page 2 This thread Refback 10-03-2011 11:09 AM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Chevrolet Impala SS Forum : Chevy Impala SS Forums This thread Refback 09-23-2011 01:53 AM
Slippery Eg Civic | RMS Forum This thread Refback 09-15-2011 04:56 PM
Fuel vapour carburetor ?? Any thoughts? This thread Refback 09-07-2011 03:38 AM
Ecotuning This thread Refback 08-30-2011 04:12 PM
DIY metro aero body This thread Refback 08-09-2011 10:17 PM
Outside Rear View Mirror - Red Pepper Racing This thread Refback 07-27-2011 11:00 PM
Aerocivic How To Drop Your Cd From 031 To 017 Page 41 Fuel This thread Refback 07-24-2011 11:12 AM
www.neons.org • View topic - My ecomodded neon. Tire spats & mini folding mirror install. This thread Refback 06-26-2011 10:16 AM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-22-2011 02:09 PM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-17-2011 06:46 PM
???????????????????????????????????????? ?????? - ??????Days This thread Refback 05-15-2011 06:05 AM
、ネ、テ、ニ、箍ツチエ、ハ・ユ・ァ・・タ。シ・゚・鬘シシヨ、ャタ萠ヌタ」チー。「・ノ・「・゚・鬘シ、ネ、ォエ、ハ、、、タ、ア、ヌ、ケ、陦ト。ト。ェ ・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 05-11-2011 10:13 AM
archives for 07/2009 This thread Refback 04-16-2011 04:56 PM
・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 04-10-2011 10:15 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 04-07-2011 01:10 AM
???????????????????????????????????????? : ?????? This thread Refback 04-01-2011 06:51 AM
Your answer to rising gas prices! This thread Refback 03-19-2011 03:45 PM
Project MMPG ~Slow build thread This thread Refback 03-07-2011 08:05 PM
I'm Dac Biet This thread Refback 03-07-2011 06:19 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 03-06-2011 06:43 AM
Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 02-24-2011 05:49 PM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-09-2011 12:35 AM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-08-2011 11:01 PM
Tobias Laboratories サ 1989 Geo Metro This thread Refback 02-04-2011 06:43 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 01-30-2011 07:41 PM
Motorbyte i moppebil - generatorfrgor This thread Refback 01-08-2011 07:09 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 01-05-2011 04:37 AM
The Nissan Path :: View topic - What octane gas do you use? This thread Refback 12-27-2010 11:43 PM
www.neons.org • View topic - ...AERODYNAMIC FAIL! This thread Refback 12-15-2010 12:19 PM
blekko | honda insight mpg at 70mph This thread Refback 11-14-2010 04:16 PM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-14-2010 06:37 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 10:18 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 07:24 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 04:58 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:56 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:53 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:40 AM
ュサエ莢Qスラーマ Discuss.com.hk This thread Refback 11-13-2010 12:40 AM
forum.group44.de • Thema anzeigen - Surftipp fr Aerodynamik- & Sparfreaks This thread Refback 10-18-2010 11:54 AM
XINeons.com View topic - custom bumper idea This thread Refback 10-08-2010 11:07 PM
Improving MPG This thread Refback 09-15-2010 01:19 AM
The 100 mpg carb - Does it really exist? This thread Refback 08-11-2010 11:16 PM
So, we haven't bashed Prius' in a while ... - LS1GTO.com Forums This thread Refback 07-27-2010 01:27 AM
1962 Mustang images & 1962 Mustang stock photos at HealthHaven.com This thread Refback 07-20-2010 10:12 PM
New transport secretary = idiot Singletrack Forum This thread Refback 06-02-2010 05:06 AM
AlterSlash ~ the unofficial SlashDot digest This thread Refback 05-31-2010 06:29 PM
www.neons.org • View topic - My ecomodded neon. Thinking about an aero front bumper... This thread Refback 05-31-2010 06:24 PM
Slashdot | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:44 AM
Slashdot Comments | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:35 AM
Slashdot Hardware Story | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 08:44 AM
新型プリウスで東京〜鹿児島〜熊本の無給油燃費記録に挑戦 This thread Refback 05-27-2010 08:10 AM
Improving MPG - Page 2 - Ranger Power Sports Forum This thread Refback 05-26-2010 12:57 AM
Your answer to rising gas prices! This thread Refback 05-11-2010 01:40 PM
Project Super zuinig... - Afdrukversie This thread Refback 04-04-2010 12:12 PM
L'aerodinamica della Civic This thread Refback 03-10-2010 07:17 PM
Wykop.pl - Ekonomiczny Civic spala tylko 2,5l litra benzyny na 100km - Powi?zane This thread Refback 02-22-2010 06:57 PM
www.HondaTuning.lt - View topic - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 02-21-2010 12:08 PM
I have yet to see a thread address this - TDIClub Forums This thread Refback 02-19-2010 01:55 PM
Aerodynamics (Project KITT) This thread Refback 02-09-2010 10:08 PM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Impala SS Forum This thread Refback 02-09-2010 07:55 PM
Homesteading Reviews This thread Refback 02-07-2010 11:25 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co mo?emy poprawi?? This thread Refback 02-05-2010 04:34 PM
【燃費】まじめに燃費向上を語り合うスレ 37km/L This thread Refback 02-04-2010 12:28 PM
I have yet to see a thread address this - Page 2 - TDIClub Forums This thread Refback 01-20-2010 07:23 AM
electroauto.ru :: ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 01-16-2010 08:05 AM
I have yet to see a thread address this - TDIClub Forums This thread Refback 01-10-2010 03:37 PM
Do it yourself aero modification This thread Refback 01-02-2010 02:55 PM
??????[??]?????????????????? This thread Refback 12-14-2009 04:23 AM
www.neons.org • View topic - My ecomodded neon. Insight tire teaser! 11-21-09 This thread Refback 11-23-2009 11:28 PM
Tailboxes work for everyone - 'BentRider Online Forums This thread Refback 11-18-2009 03:00 PM
Untitled document This thread Refback 11-17-2009 08:04 AM
Noul Logan Renault eco2, cu 3,8% consum - DaciaClub - Forum Dacia This thread Refback 11-12-2009 04:45 AM
electroauto.ru • ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 11-10-2009 11:41 AM
菴守雋サ縺ァ襍ー繧後k繧医≧縺ォ謾ケ騾縺輔l縺溘お繧「繝ュ繧キ繝薙ャ繧ッ縺ョ蜀咏悄 - darkwater 縲 縺ソ繧薙き繝ゥ 縲 繝悶Ο繧ー This thread Refback 11-04-2009 11:34 AM
Motorbyte i moppebil - generatorfr虍or This thread Refback 10-06-2009 01:23 PM
Rad blind experiment - MBClub UK Forums This thread Refback 09-25-2009 03:42 AM
www.hondatuning.lt :: Perirti tem - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 09-03-2009 10:48 AM
www.neons.org • View topic - My hypermiler. Rapid acceleration is better! This thread Refback 09-01-2009 02:56 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 08:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 01:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 09:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
