Old 01-10-2008, 07:53 PM   #51 (permalink)
Silver Bullet - '02 Golf TDi
Very cool project, basjoos! I have been playing with diesel engines in my street cars since th early 80's, though never with the body shape. My best was 72 mpg from Seattle to San Francisco (>800 miles) in my wife's new Golf TDI by doing 55 on the flats and 50 going uphill, plus the usual coasting, etc.
I studied aeronautical engineering in the Air Force (I'm a retired USAF pilot) and recognize most of the basic drag reduction features of your car. Oddly, Ford built a wonderful little FWD V-4 engine prototype aero car in the early 60's which incorporated many of the same features, though not nearly so comprehensively as you have.
You can search images.google.com for more photos with "1962 mustang prototype" (use the quotes).
Thanks for sharing!
Stan
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
Old 01-10-2008, 08:01 PM   #52 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Welcome to the site, Stan.
basjoos is definitely an inspiration. Every time I look through this thread, or at his latest tweak/addition, I can't help but think, "here I am staring at the computer screen again instead of doing something!"
PS - that's great mileage in the Golf.
Old 01-10-2008, 11:08 PM   #53 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
MikeF, I don't know if the air in the front wheel wells is low pressure, but they are the main exhaust ports for my engine compartment and get the job done. I also exhaust a smaller amount of air out through the central hump (where it cools the exhaust pipe and catalyitc converter) to the right rear wheel well.
aerocivic.com
Old 01-11-2008, 12:28 AM   #54 (permalink)
Thanks for the info, basjoos.
Michael
'71 240Z RB20DET
'99 Toyota Echo (Yaris) sedan.
Old 01-11-2008, 02:08 PM   #55 (permalink)
basjoos's Avatar
I've been pondering and haven't decided yet which layout would be better. My current setup of air divider/front wheel/double side skirts/rear wheel/boattail, or alternatively to have a air divider/front wheel/boattail//air divider/rear wheel/boattail. The side skirts help to keep the air flow linear between the front and rear wheels, but has more wetted area than the alternative layout. Where's a full-sized backyard wind tunnel when you need one?
aerocivic.com
Old 01-11-2008, 03:00 PM   #56 (permalink)
Based on extensive CFD studies we've done for racing customers I think having just the outside skirt between the front and rear tires is your best (lowest drag) option. That's because the outside skirts keep air from migrating down from the sides of the car to under the car. This reduces the disruption of the airflow and added turbulence under the car, and hence reduces drag. That's why nearly all racing rules prohibit skirts down below the bottom of the car frame.
Your "tire spats" do add a fair bit of extra wetted surface. A trick we use on race cars to reduce wheel opening drag is to add a small "Gurney Flap" to the leading edge and top of wheel openings. This photo shows a roughly trimmed left-rear fender we made recently for a customer's sports car.
You can see that the bodywork turns out 90-degrees right at the edge of the wheel opening. That turn-out needs only be a centimeter or so tall, but it does two things for you. First, it creates a low pressure area outside the wheel opening which helps evacuate air from the wheel well. Second, it diverts the freestream air away from the wheel and tire, thereby reducing the drag component of those pieces.
There's no free lunch, though, aa the flaps do add incremental drag, but possibly less than the spats they would replace.
Stan
Old 01-11-2008, 03:20 PM   #57 (permalink)
Stan - I know there are rarely simple answers in aerodynamics, but can you say whether skirts in racing are primarily meant to reduce overall drag, or are they there to retain a pressure differential between ambient, and the lower pressure underneath the vehicle (for more downforce)?
I haven't seen much written about skirt use on road cars, specifically for drag reduction - except a suggestion that in a crosswind situation, skirts will increase projected area in the "apparent" direction of travel through the wind.
Darin
Old 01-11-2008, 04:46 PM   #58 (permalink)
Stan: I think your racing customers are dealing with a lot less air flow under the body of the car.
Old 01-11-2008, 04:49 PM   #59 (permalink)
The short answer is "yes"...the longer answer is..."it depends". Old aero joke...sorry.
Joking aside, many high performance techniques will transfer well to maximizing fuel economy. Not the particular solutions, mind you, but the techniques of, in this case, airflow management.
Racecars seeking downforce generally fall into one of two categories, flat-bottomed or tunneled. Flat-bottomed cars are just that. The underside of the car has to be built on one plane from side to side and front to rear except for specific exceptions, such as openings for the tires. Tunnel cars are permitted varying degrees of camber to their undersides. Both types of cars generate downforce by varying their ground height and "rake" (the difference in ground clearance between the front and rear). Both also seek to maximize downforce by employing side skirts whenever permitted to maintain nice linear flow under the car from front to rear.
Looking at the photos of basjoos' car, especially these two...
...it is clear to me that his car has considerable camber along its longitudinal axis. The leading edge of the nose appears to be about a foot off the ground. The bottom then dips down to within ~4" of the ground, and then gradually rises back up to the trailing edge of the car. In aero terms, basjoos has created a classic venturi, with a convergence zone at the front, a throat in the middle, and a diffuser at the rear. And since he writes that the car is stable up to 100 mph, my guess is that Aerocivic is producing modest net downforce. This added downforce comes at the cost an increase in induced drag. That said, the total induced drag on such a narrow-span "wing" (the car is only 5' wide or so) is slight. In other words, there is enough downforce to securely "plant" the car to the ground, but not enough to cost him much net fuel efficiency.
Basjoos, have you done any back-to-back fuel economy measurements with and without the side skirts? My guess is that they are giving you a measurable boost in FE. The question in my mind is whether you need both the inner and our skirts. I am fairly confident that if you remove the skirts and put boat tails behind the front tires that your fuel economy will suffer.
Be fun to find out, though!
Stan
Old 01-11-2008, 05:45 PM   #60 (permalink)
Yes, you are quite correct, which is why I noted in my most recent post that it is the techniques that will cross over, not necessarily the particular solution.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
Posted By For Type Date
Aerocivic - how to drop your Cd from 0.31 to 0.17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 01-23-2012 08:53 AM
Week of November 21st - November 27th, 2011 (Nat Avg $3.37) - Page 4 - CleanMPG Forums This thread Refback 11-25-2011 11:27 AM
Overdrive.fiョ | N艙t viesti - Pisaralla pisimmlle -jenkki This thread Refback 10-12-2011 03:58 AM
Anyone have a 1.7 cdti ? • Honda Civic Forum This thread Refback 10-05-2011 07:07 PM
Improving MPG - Page 2 This thread Refback 10-03-2011 11:09 AM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Chevrolet Impala SS Forum : Chevy Impala SS Forums This thread Refback 09-23-2011 01:53 AM
Slippery Eg Civic | RMS Forum This thread Refback 09-15-2011 04:56 PM
Fuel vapour carburetor ?? Any thoughts? This thread Refback 09-07-2011 03:38 AM
Ecotuning This thread Refback 08-30-2011 04:12 PM
DIY metro aero body This thread Refback 08-09-2011 10:17 PM
Outside Rear View Mirror - Red Pepper Racing This thread Refback 07-27-2011 11:00 PM
Aerocivic How To Drop Your Cd From 031 To 017 Page 41 Fuel This thread Refback 07-24-2011 11:12 AM
www.neons.org • View topic - My ecomodded neon. Tire spats & mini folding mirror install. This thread Refback 06-26-2011 10:16 AM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-22-2011 02:09 PM
Honda Civic Forum • View topic - Anyone have a 1.7 cdti ? This thread Refback 05-17-2011 06:46 PM
???????????????????????????????????????? ?????? - ??????Days This thread Refback 05-15-2011 06:05 AM
、ネ、テ、ニ、箍ツチエ、ハ・ユ・ァ・・タ。シ・゚・鬘シシヨ、ャタ萠ヌタ」チー。「・ノ・「・゚・鬘シ、ネ、ォエ、ハ、、、タ、ア、ヌ、ケ、陦ト。ト。ェ ・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 05-11-2011 10:13 AM
archives for 07/2009 This thread Refback 04-16-2011 04:56 PM
・ル・「・・・ー2chシォニーシヨ・ヒ・蝪シ・ケ This thread Refback 04-10-2011 10:15 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 04-07-2011 01:10 AM
???????????????????????????????????????? : ?????? This thread Refback 04-01-2011 06:51 AM
Your answer to rising gas prices! This thread Refback 03-19-2011 03:45 PM
Project MMPG ~Slow build thread This thread Refback 03-07-2011 08:05 PM
I'm Dac Biet This thread Refback 03-07-2011 06:19 AM
とっても安全なフェンダーミラー車が絶滅寸前、ドアミラーとか危ないだけですよ……! This thread Refback 03-06-2011 06:43 AM
Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 02-24-2011 05:49 PM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-09-2011 12:35 AM
Hey Volkswagen, fixed the L1 Concept for you : pics This thread Refback 02-08-2011 11:01 PM
Tobias Laboratories サ 1989 Geo Metro This thread Refback 02-04-2011 06:43 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 01-30-2011 07:41 PM
Motorbyte i moppebil - generatorfrgor This thread Refback 01-08-2011 07:09 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co moソemy poprawi? This thread Refback 01-05-2011 04:37 AM
The Nissan Path :: View topic - What octane gas do you use? This thread Refback 12-27-2010 11:43 PM
www.neons.org • View topic - ...AERODYNAMIC FAIL! This thread Refback 12-15-2010 12:19 PM
blekko | honda insight mpg at 70mph This thread Refback 11-14-2010 04:16 PM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-14-2010 06:37 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 10:18 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 07:24 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 04:58 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:56 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:53 AM
EG Civic ・]ウ, ・ムCd 0.34 ューヲワ 0.17 - ィTィョ - ュサエ莢Qスラーマ discuss.com.hk - 、@ュモュサエ茹uアo、@ュモュサエ莢Qスラーマ This thread Refback 11-13-2010 12:40 AM
ュサエ莢Qスラーマ Discuss.com.hk This thread Refback 11-13-2010 12:40 AM
forum.group44.de • Thema anzeigen - Surftipp fr Aerodynamik- & Sparfreaks This thread Refback 10-18-2010 11:54 AM
XINeons.com View topic - custom bumper idea This thread Refback 10-08-2010 11:07 PM
Improving MPG This thread Refback 09-15-2010 01:19 AM
The 100 mpg carb - Does it really exist? This thread Refback 08-11-2010 11:16 PM
So, we haven't bashed Prius' in a while ... - LS1GTO.com Forums This thread Refback 07-27-2010 01:27 AM
1962 Mustang images & 1962 Mustang stock photos at HealthHaven.com This thread Refback 07-20-2010 10:12 PM
New transport secretary = idiot Singletrack Forum This thread Refback 06-02-2010 05:06 AM
AlterSlash ~ the unofficial SlashDot digest This thread Refback 05-31-2010 06:29 PM
www.neons.org • View topic - My ecomodded neon. Thinking about an aero front bumper... This thread Refback 05-31-2010 06:24 PM
Slashdot | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:44 AM
Slashdot Comments | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 09:35 AM
Slashdot Hardware Story | UK Students Build Electric Car With 248-Mile Range This thread Refback 05-31-2010 08:44 AM
新型プリウスで東京〜鹿児島〜熊本の無給油燃費記録に挑戦 This thread Refback 05-27-2010 08:10 AM
Improving MPG - Page 2 - Ranger Power Sports Forum This thread Refback 05-26-2010 12:57 AM
Your answer to rising gas prices! This thread Refback 05-11-2010 01:40 PM
Project Super zuinig... - Afdrukversie This thread Refback 04-04-2010 12:12 PM
L'aerodinamica della Civic This thread Refback 03-10-2010 07:17 PM
Wykop.pl - Ekonomiczny Civic spala tylko 2,5l litra benzyny na 100km - Powi?zane This thread Refback 02-22-2010 06:57 PM
www.HondaTuning.lt - View topic - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 02-21-2010 12:08 PM
I have yet to see a thread address this - TDIClub Forums This thread Refback 02-19-2010 01:55 PM
Aerodynamics (Project KITT) This thread Refback 02-09-2010 10:08 PM
any ways to improve areodynamics and coeffiecent of drag - Page 5 - Impala SS Forum This thread Refback 02-09-2010 07:55 PM
Homesteading Reviews This thread Refback 02-07-2010 11:25 AM
Corsa-A.pl Team :: Zobacz temat - Aerodynamika Corsy - co mo?emy poprawi?? This thread Refback 02-05-2010 04:34 PM
【燃費】まじめに燃費向上を語り合うスレ 37km/L This thread Refback 02-04-2010 12:28 PM
I have yet to see a thread address this - Page 2 - TDIClub Forums This thread Refback 01-20-2010 07:23 AM
electroauto.ru :: ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 01-16-2010 08:05 AM
I have yet to see a thread address this - TDIClub Forums This thread Refback 01-10-2010 03:37 PM
Do it yourself aero modification This thread Refback 01-02-2010 02:55 PM
??????[??]?????????????????? This thread Refback 12-14-2009 04:23 AM
www.neons.org • View topic - My ecomodded neon. Insight tire teaser! 11-21-09 This thread Refback 11-23-2009 11:28 PM
Tailboxes work for everyone - 'BentRider Online Forums This thread Refback 11-18-2009 03:00 PM
Untitled document This thread Refback 11-17-2009 08:04 AM
Noul Logan Renault eco2, cu 3,8% consum - DaciaClub - Forum Dacia This thread Refback 11-12-2009 04:45 AM
electroauto.ru • ???????? ???? - ???????????????? ????? ?? ?????????????? This thread Refback 11-10-2009 11:41 AM
菴守雋サ縺ァ襍ー繧後k繧医≧縺ォ謾ケ騾縺輔l縺溘お繧「繝ュ繧キ繝薙ャ繧ッ縺ョ蜀咏悄 - darkwater 縲 縺ソ繧薙き繝ゥ 縲 繝悶Ο繧ー This thread Refback 11-04-2009 11:34 AM
Motorbyte i moppebil - generatorfr虍or This thread Refback 10-06-2009 01:23 PM
Rad blind experiment - MBClub UK Forums This thread Refback 09-25-2009 03:42 AM
www.hondatuning.lt :: Perirti tem - Aerocivic - how to drop your Cd from 0.31 to 0.17 This thread Refback 09-03-2009 10:48 AM
www.neons.org • View topic - My hypermiler. Rapid acceleration is better! This thread Refback 09-01-2009 02:56 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 08:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 01:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 09:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
