Old 12-04-2010, 02:01 AM   #21 (permalink)
XBox'er
Originally Posted by jimepting View Post
You can make cheap wheel covers using pizza pans from Wal-Mart.
That's a great idea. I figure coroplast would be too flimsy and sheet metal too thin. Pizza pans it is. Off to Wal-Mart.
Old 12-04-2010, 09:10 AM   #22 (permalink)
redyaris - '07 Yaris
90 day: 47.98 mpg (US)
Gray - '07 GS500 F
Motorcycle
90 day: 70.4 mpg (US)
KLR - '07 KLR650
Last 3: 62.78 mpg (US)
I would advise against working under a vehicle supported by cinder blocks. they have been known to fail and allow the vehicle to fall down and kill people.
Old 12-05-2010, 06:11 PM   #23 (permalink)
Modder2B
White Variant - '96 Passat TDI ~ GlS- 4 Cyl
Cinder blocks have a similar reaction to paper, when they give, they GIVE and it is a catastrophic raction!
Don't get under car unless stands are there!
Old 12-05-2010, 06:18 PM   #24 (permalink)
Modder2B
Sorry to double post...
Start the under tray from the rear 'cause wind will be coming from the front, this way it overlaps rearwards/air flow.
Great on the cross braces for the rear tray.
Don't cut it the panel, air will flow to lower pressure and then "raise" the low area to smoothen out turbulence, lot smoother and cleaner.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Honda Fit Belly Pan Project Fit Aerodynamics 15 03-10-2011 04:32 PM
belly pan thrash 2008 lovemysan Aerodynamics 12 09-23-2009 07:51 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
Belly Pan on the Saturn Raysp30 Aerodynamics 8 07-14-2008 01:46 PM
