Old 07-30-2010, 03:12 PM   #1 (permalink)
Aerodynamic simulations for Toyota Tacoma
Hi all,
Before attempting to build or buy an aerodynamic truck cap, I decided to do some simulations using Chernyshenko's popular program.
Here are the results:
Enjoy...
The Following User Says Thank You to Varu For This Useful Post:
ChazInMT (07-30-2010)
Old 07-30-2010, 05:59 PM   #2 (permalink)
Your slanted cap had leftover pixels from the full cap; note the pink high-pressure areas right around where the upper-rear corner of the cap was. Those create lots of drag, but are probably not going to be there with an actual slanted cap...
-soD
Old 07-30-2010, 09:27 PM   #3 (permalink)
I checked and there are no leftover pixels. (See attached.)
Maybe the vorticity spots are caused by the sharp corners of the slanted cap?
Old 07-30-2010, 10:01 PM   #4 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
Varu...First off, most excellent stacking of the Flow Illustrators, how did you do that? I'd love to be able to do the same to compare different renderings.
Next, I looked DEEPLY at your bit map.....and there are a shat load of pixels drifting about. No biggie, just next time, use your eraser really good. Flow Illustrator sees anything which isn't white (Really white) as solid. I use Paint to make my .bmps, there is a function there under, Image/Attributes to select B&W which I always do. That way no gray scale artifacts show up.
I have gotten really good using the Draw feature in Word to make outlines. Once you get used to it, Draw is super easy to trace out complex curves on a photograph. I can trace a car in about 7 Minutes. Then it is easy to cut & paste the drawing into paint, B&W it and tadaaa.
Old 07-30-2010, 11:16 PM   #5 (permalink)
Stacking takes a little effort. You have to write a script for Avisynth and then open that in Virtualdub. But... the videos produced by the website use the Indeo 5 codec, which is no longer free (Vista lacks the codec anyway). You can convert them to something useful using ffmpeg.
More info about stacking at virtualdub dot tk....
Regarding the pixels, wow I stand corrected. At 600% zoom in Paint I can see there are indeed many gray pixels in there. Oops
By the way, Chernyshenko's server is giving errors at the moment. When I tried to upload by bmp file I got "There is not enough space on the disk. : File could not be uploaded." Presumably a temporary problem.
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Group Purchase of Aerodynamic Modeling Program windrider919 Aerodynamics 16 09-10-2009 07:02 PM
Modern Rolls Royce Phantom vs Aerodynamic Coupe Unheard Aerodynamics 2 06-19-2009 10:19 PM
