Old 02-12-2011, 12:37 PM   #91 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I've had my mind on turning my Tempo into a secondary car for a bit now, and I have my heart set on finding a Civic VX. I've found a few here and there, but I never have the cash on hand.
Tax returns are coming in at the end of the month, and it looks like it'll be enough to buy the next one I find!
I laid the template over the EG hatch, and found it has the perfect roofline already.
As you can tell, I plan on adding a kammback to it, and making the rear end a vertical square surface.
I'll start a thread on it when I finally get one.
In Reason we Trust
The Following User Says Thank You to AeroModder For This Useful Post:
cfg83 (02-12-2011)
Old 02-12-2011, 01:29 PM   #92 (permalink)
I might be off-base with this, but to my eye it appears the template's curve is getting a little funky?
Old 02-12-2011, 03:24 PM   #93 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
As precise as I can git to tracing things...it's the best I can do at the moment. Perhaps you would like to check my work...I'll be happy to send you my OpenOffice Draw file...
That's why I included this piccie, too!
Old 02-12-2011, 05:45 PM   #94 (permalink)
I mean, even on the first one with the teardrop car. It's not a "mathematically smooth" curve to my eye.
It's not identical to this one, which does look smooth to me:
aerohead (10-13-2012)
Old 02-12-2011, 11:35 PM   #95 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Frank -
I did an overlay :
NOTE: My image may be incorrect if my choice for "apex/center of camber" is incorrect.
The (very) thin red line is the latest overlay we are looking at. The thicker green line is another overlay base on this image :
The 9.0 degrees is an interpretation of the red and green lines. The 12.7 degrees is the slope of the "shadow" over the EV-1. The EV-1 "shadow" is closer to a straight line from the apex, while the other slopes are more more curved (I hope that makes sense).
Base on the slopes I am seeing, I am going to split the difference and say that the "goal" should be an angle of close to 11 degrees (at least for the EV-1).
CarloSW2
American Solar Energy Society
Old 02-13-2011, 08:11 AM   #96 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
cfg,
I believe you should be ignoring the bottom of the thick green line and using only the top of that line. That would bring the three curves closer into agreement as well.
The goal should be a compound curvature, with no discontinuities in the first or second derivatives ("smooth"). If BZP's green tracing joined multiple splines (or worse, lines) with verticies, that would explain why it "looks off".
Old 02-13-2011, 03:17 PM   #97 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
RobertSmalls -
Ok, here's the revised version, and I agree that they are very similar :
Even though I have been using the thick overlay incorrectly in previous posts, I think the inside/outside of the thick line is "close" enough and I feel I needed to see the vehicle for easier mod-visualization.
With that said, I will probably switch to this one :
It is now a 16-color gif with only black and white being used. This makes it easy to do transparent overlays. The above image is at 780 pixels for fitting into an ecomodder album, but I will attach a non-downsized image in a subsequent post.
CarloSW2
Old 02-13-2011, 08:25 PM   #98 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
Here is the bigger version.
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
BamZipPow (02-13-2011)
Old 02-13-2011, 09:38 PM   #99 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Are you sure about those numbers? I'm showing 0, 3.5, 7.5, 12, 15, 18.5, 21, 22, 22, 22...
Old 02-13-2011, 10:04 PM   #100 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
BamZipPow -
Nope, I'm not sure, it's the best I could read and cross-reference from the initial image. I can make a new one with those numbers.
CarloSW2
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
