Old 06-12-2014, 07:00 PM   #11 (permalink)
Originally Posted by JasonG View Post
Yeah, I didn't want the work of a teardrop so I was planning on a straight sloping parallelogram.
Well ,here's how you can have your cake and eat it too.
I'll try to explain.
First build your box or whatever shape with it open at the top. (sides, front, back and bottom)
Then build a over lapping top. Flat on top, triangle sides and a front panel. No rear panel.
Put a hinge at the back of the trailer on the top and or sides.
Attach the over lapping top to the hinge at the back of the trailer.
To access the trailer you could either tilt the top, remove the top or make a tailgate that lowers. You could also add a door in the front for easy access when you go camping.
Lift and lock the front of the top in the up position when traveling for aero.
Lower it when you want a flat work surface.
If and when you go camping, when in the up position you will have more room and be able to sit up.
If I could draw it, I would.
Old 06-12-2014, 07:26 PM   #12 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Yeah, I like it redneck.
I planned on hinging the top in the front for access.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 06-12-2014, 07:29 PM   #13 (permalink)
Had another thought.
If you make the top longer and let it extend past the hinge points it would act like a Kammback and also extend your work surface.
Old 06-14-2014, 03:22 PM   #14 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
If you want to go with a swivel wheel type similar to my single wheel trailer, give Toy-Tote.com a visit.
The Ultra-XXL is a 65"x100" with a 1600lb capacity. I really like the dual wheel setup. I would totally rob that trailer fer the dual wheel setup.
Ultra XXL - Toy Tote
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (06-14-2014), mikeyjd (06-14-2014)
Old 06-14-2014, 09:35 PM   #15 (permalink)
JasonG's Avatar
Yeah, it's a shame nobody sells just the swivel wheels anymore.
I'm too cheap to cut up a new trailer.
