Old 11-06-2010, 08:28 PM   #81 (permalink)
I have to start over?
Big inefficient truck - '94 Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Civic DX Hatchback
Actually, it does (did) have a renault(?) 2.1 TDI optional at the factory, which was wildly unpopular, for the same reason most 1980's diesels were so unpopular. I believe it had a standard option and, of course, 4x4 as an option.
Yes, I used some square tubing from something (???) I rescued from a dumpster. I just welded onto the bumper. The bumper is not very thick steel (10 GA, maybe) and thus not very strong. I only welded onto the bumper because I wanted it so that if I hit something, I wouldn't bend my frame (more than it is bent now). And because I'm lazy.
maybe this? Or this?
Old 11-09-2010, 09:24 PM   #82 (permalink)
This evening I put on my half belly pan! It is a 4x8 sign with a 8" by 48" rectangle cut off to make the front fit between the tires.
For the support needed, I welded studs (threaded metal, not wooden 2x4s) onto my frame near the front and rear suspension mounts. Then I bolted a 6 foot 2x2 piece of wood onto them, and simply screwed the coroplast onto it with washers. The front zip ties onto the bottom of the airdam supports (which I raised about 1.5 inches, and angled forward more).
The beams put the anchor lines a few inches lower, making the coroplast have plenty of clearance for the exhaust, namely the catalytic converter. After a test drive, the plastic was warm but not too warm. I'm sure it still gets plenty of airflow to keep it cool
There wasn't really enough light to get pictures, I'll try to remember tomorrow
Old 11-09-2010, 10:56 PM   #83 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
I would slap on a strip of aluminum flashing between the coroplast and the exhaust system. I found out on my setup that part of the problem wasn't when I was driving but after I had come to a stop and shut down. The radiant heat from the muffler was enough to melt the coroplast even though it was over 4" away and since there wasn't any airflow to keep the temps down
Old 11-10-2010, 10:35 PM   #84 (permalink)
Tank driver
OD - '05 Econoline
90 day: 14.59 mpg (US)
Camo - '99 Windstar
Team Ford
90 day: 25.22 mpg (US)
Joetta - '86 Jetta Turbo Oil Burner
90 day: 50.35 mpg (US)
Neat old willys.
"A man is not finished when he is defeated. He is finished when he quits."
Richard M. Nixon
"The reward of suffering is experience."
Harry S. Truman
Old 11-11-2010, 10:04 AM   #85 (permalink)
Here are the pics;
That is a 2x2 running from the front to the back, and I just screwed the sign onto it from beneath. I may close it up a bit more with a piece between the outside edge of the sign and the bottom edge of the body panels.
That is one of the 4 studs (bolts) I welded on. MMMMM, ugly
And that is the front end, zip-tied onto the repositioned airdam support
Aerocivic - how to drop your Cd from 0.31 to 0.17 basjoos Aerodynamics 558 04-29-2012 10:18 PM
Cousin scored a stereotypical "old lady's" car - 10 y/o Tercel, 3k miles. MetroMPG The Lounge 11 09-14-2010 10:21 AM
help W/ Remote Kill Switch Idea 93hatchDX DIY / How-to 21 07-31-2008 03:46 PM
