Old 07-30-2008, 05:16 PM   #11 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Sounds like you'll be home-work-home on one gallon in no time! Those wheel wells are at the extreme rear of the car, so you should see a big gain. If your ride to work involves lots of highway, you could be really close to your goal!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 07-30-2008, 06:21 PM   #12 (permalink)
homeworkhome53's Avatar
Workride - '07 Aveo5 SVE
90 day: 51.74 mpg (US)
Reached my goal already (2 weeks ago) just going to see how far I can go.
homeworkhome53
Old 08-18-2008, 10:05 AM   #13 (permalink)
Scooter - '06 Aveo Barebones!
90 day: 38.64 mpg (US)
Grats
Congrats on your 53mpg goal. Gotta try my hand at those wheel well covers and a grill block myself. Was thinking of black duct tape to start that way I can fiddle with the right size and be able to easily peel off if I overheat. Any suggestions?
Old 08-18-2008, 07:11 PM   #14 (permalink)
Unclecueball
3M has a dark gray duct tape they call 3X which sticks better than most I've used it for a lower grill block and partial body pan from the fender to the radiator. Works good
Homeworkhome53
Old 08-18-2008, 08:24 PM   #15 (permalink)
well covers look great...forgive my ignorance here.. what exactly is coroplast, and gylon?...I'm sure I could work with either of them, if I knew where to get some...
Old 08-18-2008, 09:19 PM   #16 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
Coroplast is a corrugated plastic sheet -- often used for signs, and the bins that the Post Office uses. Very durable and resistance to many solvents. It is usually 4mm thick, and comes in about 8 or 12 colors.
The OP describes Gylon here.
I would also mention Gorilla Tape -- black (somewhat shiny, with a light gray sticky face), very tough, and very sticky.
Jeep Cherokee Aeromods FastPlastic Aerodynamics 246 05-10-2012 09:08 AM
Aeromods V1.0 trikkonceptz Aerodynamics 50 10-14-2011 11:30 AM
Some nice Photoshop pics of aeromods from a Ford Taurus forum MetroMPG Aerodynamics 11 10-09-2008 03:16 AM
Aeromods on a 99 Malibu GreenTeach Aerodynamics 11 06-12-2008 10:09 PM
corvair aeromods lovemysan Aerodynamics 5 04-26-2008 04:43 PM
