Old 09-15-2009, 01:49 AM   #31 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I never cut springs, I just chain the vehicle down and heat up a couple coils to weaken them, then leave the vehicle chained down until they cool.
Does the Tempo have coil overs? I can't recall... One of my Civics, I dropped it 40mm with 400 front and 330 rear spring rates (slightly higher than stock) and the struts were blown 2 days later, fluid leaking from them. They were also the OEM struts, from 1989, and I was running 205/40R16 tires, which could explain alot as well. I have seen new struts blow the seals from drop springs, though.
Old 09-15-2009, 02:49 AM   #32 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Tempos have struts all around.
I suppose it's a YMMV thing, if your model doesn't have as much travel to begin with, it has less to spare i.e. 2" "lost" is a bigger deal. Tempos have pretty generous travel for a small car.
Cutting is better than heating, I've read. The temper isn't messed up.
I've read of guys that really wanted that slammed look that removed the jounce dampers for a bit more "clearance". I'd imagine they experienced a lot of strut failures. I'd think even with the donuts in, if they were hit up against often and hard enough, that would wreck the strut too. Combine that with mag adverts and adverts disguised as articles with the intent of pushing new aftermarket product and voila- "all stock struts will fail with dropped springs"- it becomes urban legend.
Old 09-15-2009, 03:49 PM   #33 (permalink)
Steve - '92 Festiva
Yes, cutting is better than heating, but cold cutting is better than torch cutting, as well. (Same reason.) I've never experienced a failure with heated springs, but I always heat one end of the spring until the coils are compressed, so it takes them out of the equation altogether, leaving the usable coils tempered as normal.
I'm not sure about other cars, but on my Civic, the strut mounts can be modified to move the strut back up where it should be after lowering, and regain lost suspension travel.
The modification leaves the on-shaft bump stops in place, as well, by moving them up into the newly created area in the mount.
If you need a visual, I can try to find one for ya.
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
Toyota to develop affordable hybrid vehicle (to compete with new Insight) Daox Hybrids 6 03-13-2009 10:51 PM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 10:21 PM
CA Vehicle Code - Mirrors thebrad Aerodynamics 2 08-30-2008 11:03 PM
