Old 04-07-2010, 05:33 PM   #1 (permalink)
PSmodder lurker
botsapper's Avatar
Aftermarket Active Aerodynamics
Here's an example of aftermarket aerodynamics at work. The dynamic rear wing was refined w/ CFD modelling and rigorous wind tunnel testing. The system consists of pitot tubes, unique split rear wing & proprietary controller modules. I realized that it was designed for top performance dynamics but its capabilities in data gathering & analysis could be used for active LOW drag configurations, cooling/venting (only when req'd), counteracting boat tail induced crosswinds, aero-braking & overall aero-safe road stability.
AEROMOTIONS VIDEOS
Old 04-07-2010, 10:16 PM   #2 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
The spirit of Jim Hall lives on...
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 04-07-2010, 11:48 PM   #3 (permalink)
Thank you for sharing
That is cool stuff.... I thought something like this was made illegal in F1 a few years ago.
Old 04-10-2010, 03:03 PM   #4 (permalink)
Aftermarket
As Howard Hughes would say,"It's the way of the future."
There is so much good,robust,intelligent,interactive electro-mechanical technology that it would be lame to not think of it as commonplace in the future.
All the really low-drag,high-mpg concepts use it,it won't come soon enough!
Thanks for the 'glimpse.'
Old 04-11-2010, 11:02 AM   #5 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
would probably be even beter (cooler) if the wing was flexible to that it would warp rather than be split.
bmw's and some other cars are slowly starting to use active grill blocks, so perhaps in the near future more moving bits will start to appear
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Hub cap drag versus weight and heat bryan11 Aerodynamics 7 01-13-2010 02:37 AM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
New rules encourage PEHV aftermarket in California Ptero DIY / How-to 2 05-15-2009 01:36 AM
Video: hillbilly active aerodynamics MetroMPG Aerodynamics 11 01-15-2009 02:10 AM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
