Old 08-25-2008, 02:29 PM   #1 (permalink)
Neon1 - '97 Neon highline
90 day: 27.26 mpg (US)
Aftermarket Cruise Control setting for economy
I have an aftermarket Audiovox cruise control in my pickup. I had a wire cut through, so while re-wiring it and having the book out, I found some switch settings...one of which controls the response of the unit.
For testing, I am setting this to it's lowest setting which should mean that it "pushes" the pedal to the floor slower. This should equate somewhat to being more gentle on the acceleration.
I don't drive the truck too much, but do have a log on MPG for it, so I should know whether or not it works in the next month or two... (giving several runs to get more solid results)
So...anyone else tried this?
Jim
Old 08-25-2008, 03:17 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I don't have a cruise control, but that's interesting. Does it let you slow down up the hills as well?
Old 08-25-2008, 04:20 PM   #3 (permalink)
It eventually gets to the same point on the throttle that it always did, it just takes longer. The cable does not have as much lenth as the pedal, so it never gets to WOT anyway. So up a hill, I do lose more speed that I used to, but up shorter rolling hills it now does not get to it's max point....so I have to imagine it is making some difference. Good or bad, time will tell....
Jim
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 03:36 PM
Cruise control hack/modification? ArtFox DIY / How-to 7 02-18-2010 06:02 PM
Idea: hypermiling cruise control rjacob EcoModding Central 5 04-14-2009 03:17 AM
Aftermarket Cruise Control homeworkhome53 DIY / How-to 19 12-10-2008 08:07 PM
Cruise control mod idea rjacob DIY / How-to 18 07-30-2008 12:27 AM
