Old 12-20-2011, 07:37 PM   #1 (permalink)
Big Comfy - '00 Lesabre Limited
90 day: 22.28 mpg (US)
Vannie - '03 Venture Plain
90 day: 24.74 mpg (US)
Wife's Beast - '01 Sante Fe
90 day: 21.47 mpg (US)
Air Blocks and Rudolf
Thought I'd post the cause and effect of blocking the front of the Vannie. Slowly started blocking off in September with the upper grill opening 'til completely closed off with no noticeable effects on cooling. Did the lower with Velcro attached chloroplast. Everything is now closed including the bumper slits. The ONLY time cooling becomes iffy is when the outside temperature approaches 20C. Then I just pull of the center lower block and everything is good.
Talk about over capacity of a cooling system. It's all good for 2 to 3 mpg, faster warm ups and, most interestingly, slower cool-down when off leading to more residual heat when starting back up.
No noticeable effects from antlers and nose except for plenty of smiles and waves.
Merry Christmas everyone.
The Following User Says Thank You to Woodeden For This Useful Post:
mcrews (12-20-2011)
Old 12-20-2011, 07:53 PM   #2 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Merry Christmas and Happy Holyday
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-23-2011, 01:40 PM   #3 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Put the Antlers on the back and see if they work like air tabs ?
Merry Christmas too
No longer here. Bye, and good luck to all.
