Old 04-30-2010, 07:58 PM   #1 (permalink)
Racer XD - '06 Elantra GT
90 day: 35.42 mpg (US)
Air dam and belly pan
A few weeks ago I made and air dam with garden edging. I had bumper block and belly pan on when I did it. I found that it really helped with aero. The engine didn't have to push so hard. But kept having heat problems. I was thinking that the air dam was not letting air get under the car to let the hot air that was in the engine bay get pulled out threw the exit duct on the belly pan.
Should I have belly pan and air dam or just air dam?
Any other info about air dam's would help thanks?
2006 Hyundai Elantra GT 2.0L (Manual)
Weapon-R secret weapon intake with ram air kit ScanGauge Belly Pan
http://www.cars.com/ City 27 mpg - Highway 34 mpg
http://www.fueleconomy.gov/ City 23 mpg - Highway 31 mpg - Combined 26 mpg
Old 04-30-2010, 08:24 PM   #2 (permalink)
Intrigue - '98 Intrigue
90 day: 28.8 mpg (US)
Supra - '88 Supra
96 buick - '96 LeSaber
90 day: 26.89 mpg (US)
Vfr800 - '99 Vfr800
90 day: 42.28 mpg (US)
I think your better off with the belly pan with out the air dam. What I would like to do on my caprice is pick up a 2nd hood and put some kind of vent like an evo or maybe cut holes in the inner fenders
Old 05-01-2010, 12:04 AM   #3 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
You do need to make sure there is some airflow through the rad. In the winter you might get away with a full block. You need to leave an opening in your grille and in the belly pan. You can experiment with the grille by changing the block till it does not overheat. The best way would be to have a good size opening in your belly and change the rad block till optimal. Or if you are inventive, an adjustable grille block.
Is your rad fan working?
air, belly, dam, hot, pan
2007 Focus Front Air Dam garys_1k Aerodynamics 23 12-28-2011 02:22 PM
Belly pan for f-150 4x4 truck sleeeper Aerodynamics 11 01-27-2010 07:15 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
belly pan vs. air dam ? modmonster Aerodynamics 6 09-06-2008 01:40 PM
Drag Optimization of Light Trucks Using Computational Fluid Dynamics bondo Aerodynamics 16 01-21-2008 05:36 PM
