Old 01-01-2013, 11:56 AM   #21 (permalink)
SCNTN's Avatar
SC1 - '02 SC1
Team Saturn
90 day: 40.83 mpg (US)
DaGnoma - '02 Sonoma SL
Pickups
90 day: 25.03 mpg (US)
Originally Posted by nbleak21 View Post
Looking great! Any ideas on the filler?
I'm gonna give this stuff from DAP a shot. It's cheap, dries quickly, and can be sanded and painted. We'll see how it reacts with the foam.
Go Team Saturn!
Coming soon... aero accessories by LowCd!
Old 01-01-2013, 02:54 PM   #22 (permalink)
Jimmy - '00 Jimmy SLT
90 day: 23.06 mpg (US)
The White Gnat - '99 Swift
90 day: 51.09 mpg (US)
Looo-king goood!!!
The Following User Says Thank You to wmjinman For This Useful Post:
SCNTN (01-01-2013)
Old 01-01-2013, 03:45 PM   #23 (permalink)
SCNTN's Avatar
SC1 - '02 SC1
Team Saturn
Pickups
After checking out the selection of wood fillers at the local hardware store, I decided not to use the DAP product - the main agents in it are isopropyl alcohol and acetone, which I feared would have eaten the foam. Instead, I'm using Elmer's wood filler Max. It is described as interior/exterior, sandable and paintable, and appears to be water-based with no solvents. And at about $10/quart, it was a better deal. Perfect.
Here's what we have after two coats. I'll apply a third coat later and then starts the sanding...
Name:	2013-01-01 14.35.35.jpg
ID:	12159  Click image for larger version
Name:	2013-01-01 14.35.31.jpg
ID:	12160  Click image for larger version
Name:	2013-01-01 14.35.39.jpg
Go Team Saturn!
Old 01-02-2013, 03:58 PM   #24 (permalink)
SCNTN's Avatar
SC1 - '02 SC1
Team Saturn
Pickups
I went ahead and installed the grille block for the commute today. Warmup time was MUCH faster. I was at full temp in about 3 miles, right about the time I hit the highway. Normally, I'm on the highway for several minutes before I even start getting heat. I saw no issues with overheating. In fact, the temp stayed right about the same as before the grille block, right under 180 degrees. Next mod on the list will be a hi-temp (195*) thermostat...
Go Team Saturn!
Old 01-02-2013, 04:39 PM   #25 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Kia - '06 Sportage EX
90 day: 23.63 mpg (US)
very creative!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-02-2013, 05:19 PM   #26 (permalink)
Good job!
Old 01-02-2013, 08:58 PM   #27 (permalink)
halos.com
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 18.76 mpg (US)
the Avenger - '08 Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by mcrews View Post
very creative!
Agreed! In fact, this gives me an idea... I tested a near full grill block on my truck and found a 1% FE decrease. However, an idea I've bounced around is to fab a small Daytona nose shape (1969, to be exact) to the front of my truck. Or maybe a bird beak shaped nose in front of the grill. I figure the sloped/beaked nose would give better FE results. -->Never thought of using gap filler foam. Might have to try that.
Old 01-02-2013, 11:16 PM   #28 (permalink)
SCNTN's Avatar
SC1 - '02 SC1
Team Saturn
Pickups
For something that large, they sell expanding foam in a two-part setup. Base + activator I believe. Build a form, mix it up, and pour in.
Also, the "max-fill" product that I used left some considerable sized air pockets inside, which made the wood filler essential (and a PITA). The formula they sell for doors and windows expands minimally, and is denser, which makes for a highly sandable/workable product compared to the super expanding stuff. I would imagine that just a quick skim coat would be necessary if you were topping over that. Although you could use the max-fill to fill the large voids, shape it to a little smaller than you need, and then top-coat it with the dense foam for the finish.
The wood filler also seems to be rather brittle. Just from the commute today, I have a few cracks that have developed right in the middle under the logo. I think once I have the final sanding done, I'll top it all off with a coat of epoxy just to add to the rigidity.
Go Team Saturn!
Old 01-02-2013, 11:33 PM   #29 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 44.85 mpg (US)
Here is my version of foam grille blocks. I used 2-part foam and epoxy resin.
Lower & Upper Grille Block Ideas (Toyota Echo)
Mauricio
Old 01-03-2013, 12:40 AM   #30 (permalink)
SCNTN's Avatar
SC1 - '02 SC1
Team Saturn
Pickups
Beautiful work! That 2-part foam is definitely the way to go!
Go Team Saturn!
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
