Old 04-21-2011, 06:43 PM   #1 (permalink)
Leviticus - '97 Sebring Convertible JX
90 day: 21.33 mpg (US)
Fiesta - '012 Fiesta SE
90 day: 30.53 mpg (US)
Air Filter
A clean air filter means more air gets to the engine more easily. It seems the best air filter is the K&N ones, it claims it can increase horsepower by 1-2. Even if it didn't increase hp, would this also help mpg a bit because it's so efficient?
Old 04-21-2011, 06:49 PM   #2 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
in theory yes, because a restrictive airfilter restricts air just as a throttle body, and a less restrictive filter COULD reduce throttling losses compared to a more restrictive one, BUT the only way to know for sure would be to run some A-B-A tests, though i'm sure it would be insignificant
Old 04-21-2011, 06:49 PM   #3 (permalink)
A high quality disposable paper air filter will out flow and out filter a K&N.
BMW E30 air filter tests
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Old 04-21-2011, 06:54 PM   #4 (permalink)
That's what I was thinking, difference would be small, but every little bit helps, Thanks!!
Old 04-21-2011, 07:05 PM   #5 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
That and a more efficient air filter will help if it is the biggest restriction in the intake tract. However it is not. The throttle plate is the biggest restriction at partial throttle settings, you know, the ones you use most of the time when driving.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 04-21-2011, 07:08 PM   #6 (permalink)
Air Filtration Test
look up the conversion of inches of water to PSI and you'll see the difference is miniscule at best. I'm not doubting the results, but put them in terms that we readily use and you'll see the difference is little to none. besides, the OEM filter on a BMW is no doubt of higher quality than most cars being hypermiled.
Old 04-21-2011, 07:16 PM   #7 (permalink)
(.26) inch water (4°C) = 0.009392835 pound-force/square inch.
that's the spread from worst to best.
Old 04-21-2011, 10:16 PM   #8 (permalink)
MANN/Mahle makes air filters for most cars using the same material. All you really have to do is avoid Fram and you pretty much beat a K&N.
Exactly. So get the paper filter, save some money and get better filtration. There is no reason to waste your money on a K&N.
Old 04-21-2011, 10:58 PM   #9 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
There are also comments on the infiniti Forums that the oil from the K&N can affect the MAF sensor.
and that is a bad thing.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-22-2011, 12:10 AM   #10 (permalink)
ZX - '97 ZX Monaco
OldContinents
90 day: 39.4 mpg (US)
It can, wire type sensor is more prone to damage, occurs mostly when filter is soaked with oil.
But it is awful lot of work to wash and oil filter every few thousand miles, if not done, then it becomes almost same as not having a filter in first place.
My car's original filter is made from foam, similar to one found from mattresses or some car seats, there is paper version for smaller engine models that does fit and I have been using that, because it is a lot less of problem.
Mine is diesel so there is no losses from throttle butterfly, however only thing I have found is that car is lot noisier when using that foam filter, boost is not coming in any earlier. I did tested some K&N filter as had one lying around, boost came on bit sooner, horrible noise and probably worse filtering, also probably increases diesel consumption as it was impossible to drive normal speed without going to boost, but with paper filter that is very easy.
As you know in old diesel rpm plays big part from boost, I can have boost at engine braking if I use over 2500rpm and pump increases amount of injected diesel according to boost.
