Old 07-24-2008, 04:02 PM   #1 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
Air filter
I've heard about some people removing the air filter and then replacing it with some kind of cloth and supposedly they get better fe. Does anyone know what the cloth is? And why does it increase your fe over an air filter? Is the cloth still ok to use instead of an air filter?
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 07-24-2008, 04:16 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Some aftermarket filters use an oil soaked foam or cotton filter media. However, aftermarket air filters do nothing for fuel economy despite their advertisements.
Old 07-24-2008, 04:42 PM   #3 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ranchero GT
Spaz - '83 S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
If you want a low flow filter buy one, don't throw a sock (cloth) over the intake and call it good. You will run into problems with crap going into the fuel system and engine.
Honda...the economical, renewable resource.
Old 07-24-2008, 05:04 PM   #4 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
I think you're confusing filter vs cloth with paper filter vs cloth filter. They are both air filters specifically designed for your car, but one is disposable and one is cleanable. Don't buy a cleanable one. I'm an idiot for buying one. They don't pay themselves back for a long time (since you have to buy cleaning and oiling pack) and they sure as hell don't make your car any more powerful.
Old 07-24-2008, 07:21 PM   #5 (permalink)
EP3 - '03 Civic Si
90 day: 31.73 mpg (US)
Scooter - '93 Elite 80
90 day: 74.87 mpg (US)
Ape - '07 Sportcity 250ie
90 day: 66.97 mpg (US)
I saw an improvement with my k&n drop in filter. Yes they are expensive, but for my 03 civic it works. My escort rarely went over 2k and never over 3k so the engine never really pulled enough air for a better breating filter to be effective(65mph is at 3.5-3.6k on the civic). I also like the convenience, yes you have to clean them(eventually) but i don't drive that much so it will be a while. Do not try to make your own filter, anything that accedentally gets into the engine is a bad thing. Get one that is made for your car...and don't get a sponge one as they don't filter for very long.
Old 07-24-2008, 07:48 PM   #6 (permalink)
air filter
while there is much hype about aftermarket air filters,there is no laboratory evidence to confirm advertized claims.K&N was tested against factory micronic paper element filters and found to filter less effectively,foul the soonest.Don't know about "fabric" filters.Air filters are a dead end with respect to improving mpg.They provide virtually no restriction to the intake flow,and consequently have no effect on volumetric efficiency of the engine,even at wide open throttle.There surface area is carefully computed to do exactly this.Spend your money elsewhere.
Old 07-24-2008, 09:19 PM   #7 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I prefer a clean engine and only use quality filters. I use Baldwin and no other brand. I am not going to get into statistics about filtering or argue on who makes the best filter because I already answered that question.
Old 07-24-2008, 10:56 PM   #8 (permalink)
my girl - '06 malibu ls
Last 3: 44.87 mpg (US)
i put a k&n on my 2006 malibu and it gave me 2mpg's right out of the box
Old 07-24-2008, 11:18 PM   #9 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
I tried a K&N on my 6000 wagon once. I did notice a bit snappier throttle response, but no better mpg. I could also buy a lot of stock paper air filters for I paid for the K&N.
Winter daily driver, parked most days right now
Summer daily driver
Old 07-24-2008, 11:26 PM   #10 (permalink)
White 07 Civic - '07 Civic LX
90 day: 38.87 mpg (US)
Has anyone ever thought about putting a bigger box and filter into their car? Maybe there would be a bit less resistance. Just a thought
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 08:38 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 10:30 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 04:24 PM
Broken Air Filter Discovered RH77 Off-Topic Tech 2 07-03-2008 11:14 PM
