Old 01-28-2012, 05:30 PM   #1 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
air flow over Infiniti Q45 w/IMPUL body kit
On of our british members VIIO, has a software program that does the following:
(based on this photo)
Here's a model of the air velocity affecting your car at 55mph - red is slow (drag/turbulence) and green/blue is full speed air (low drag = good).
This model is of the pressure affecting the car, as you might expect, the air pressure is mainly on the front of the car and creates a bow wave similar to a boat in water. Areas in blue are low pressure and will actually be providing downforce to your car - for example underneath your front airdam lip.
Hope this helps!
Viio
Amateur SolidWorks Flow Simulator
We are going to adjust the rear to relect the rear spoiler
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
