Old 05-15-2010, 10:02 AM   #11 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Villager gs
90 day: 19.8 mpg (US)
Max - '98 Maxima SE
90 day: 26.89 mpg (US)
Originally Posted by mwebb View Post
..."I admit an increase to compression likely doesn't happen to all cars. ."... ..."" I could see how an increase in compression is possible."...
what ever you may think
(excepting the effects of EGR and variable cam timing)
the engine compression will not change on any car except some SAAB engines
which have variable compression due to a hinge strategically placed in the engine block
the words you seek are
peak Combustion pressure
but do not forget IGN timing will change based on MAP changes and
it is possible that the authors of the article you read were experiencing some of that
A cleaned up air intake can only make a difference when the throttle plate is wide open, "...
i agree with this
but i believe the OP's intent was to fabricate something to pressurize the intake
like RAM AIR on an old Pontiac ...
however i may be INcorrect --
if the OP was referring to the brightly colored garbage with conical filters that ingest hot air from under the hood sold by the alleged "performance outlets".
I found the thread. I finally got desperate and searched through my history till I found it. After rereading the last bit, I found a few important details, especially the bit about this being a turbocharged vehicle. The folks doing the mod also went to extreme lengths to remove any hint of vacuum from the intake system. But using a pressure meter they detected a slight positive pressure where they once had negative pressure; however their setup was like a beefy ram air setup, so no suprise.
I apparently took the example of an extreme setup and applied the logic to a more common setup.
Gotta love wife, kids, and car!
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 05-15-2010, 09:46 PM   #12 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
no vacuum in the intake ? i am standing beside myself .
..."The folks doing the mod also went to extreme lengths to remove any hint of vacuum from the intake system."...
if that were true "their" engine would not run.
it looks like the article's author went to great lengths to increase flow of a pre existing duct that was 50% BLOCKED by the location of a fog light ?
his modification may actually remove flow from the "oil cooler" if that is what that was ,
which may not be such a wise thing to do
Old 05-16-2010, 10:16 AM   #13 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
there are books out there on intake design and from my reading of them the large short after market intakes that you can buy are look like they might be the worst thing you can do, I don't have the math in front of me but there are formulas out there to help you figure out what size is best.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
SGII first observations! Old Tele man Success Stories 10 04-02-2010 01:26 AM
My Warm Intake & Temp #'s (mileage results tonight) Drive Stick EcoModding Central 4 03-26-2009 10:25 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 10:15 PM
