Old 12-20-2009, 12:05 AM   #1 (permalink)
Ecomodder in Training
Rainh2o's Avatar
Green Machine - '96 Contour GL
90 day: 34.9 mpg (US)
air intake resonator removal?
Anyone ever removed the air intake resonator on their car? Did it improve mpg or just get noisy?
Old 12-20-2009, 12:13 AM   #2 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
removing the air intake resonator will not increase mpg. I removed mine on my Q45 and ran a cool air duct up thru the hole it left in the bottom of the air box.
Old 12-20-2009, 01:11 AM   #3 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
It just gets noisier in most cases. If the resonator is an actual restriction in the pipe, it could potentially increase your fuel economy, depending on how you drive. If you drive like a "normal" person, it probably will, because you're probably working the throttle quite heavily. If you drive like most of us do, no chance.
I think that little point is where alot of discussions get out of hand on whether or not something will improve MPG...
Old 12-20-2009, 08:06 AM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Someone once did a semi-scientific study of this on the Insight, climbing a hill repeatedly with and without the resonator. Removing the resonator reduces horsepower at any given throttle angle between 1000-1500RPM, but has no discernable impact on engine efficiency.
I tell you what, though, once I removed mine, I could hear the engine better. It's hard to tell what the engine is up to when you can barely hear it.
Old 12-20-2009, 08:17 AM   #5 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
On Saturn S series, it really makes them sound good.
In the winter it raises the IAT a bit but not like a real WAI.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 12-20-2009, 10:18 AM   #6 (permalink)
Steve - '92 Festiva
I remember on '88-89 Civics with DPFI systems, people wanting to remove the "restrictor" plate in the intake plenum... Thinking that because the plate blocked part of the access to the throat, they'd get more HP if they removed it.
Of course, they were dead wrong. The "restrictor" plate that they were all referring to actually directs airflow into a swirl pattern into the intake throat, increasing it's velocity to help atomize the fuel better.
Old 12-20-2009, 11:45 AM   #7 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
My first civic vx was hit in the corner where the air intake is and the resonator had been broken and removed, the rest of the intake was intact, after owning the car for a few months I chose to buy a used intake so I could get that broken resonator back, engine noise dropped, engine ran smoother, power increased and my gas mileage improved slightly.
Old 12-20-2009, 12:32 PM   #8 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Sedona LX
Makes sense to me, but it also kind of reminds me of that stupid throttle body spacer "tornado" crap that "swirls" the air as it enters the manifold. Hey, if it works, more to you
Old 12-20-2009, 12:33 PM   #9 (permalink)
Steve - '92 Festiva
It's not even close. You'd actually have to see it to understand why it's necessary.
Old 12-20-2009, 12:56 PM   #10 (permalink)
Rainh2o's Avatar
Mine is actually hanging off at about a 90 degree angle to the flow of air, so its not really in the air path. I was thinking it probably wouldn't do much for MPG at first but then I starting thinking about it creating drag on the input of air then my train of thought got more technical about creating vortex drag etc etc...but that's my problem sometimes, the easiest solution gets covered up by over thinking...guess that's why I'm an engineer...LOL
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 5 10-09-2009 11:09 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
