Old 04-03-2008, 10:43 PM   #1 (permalink)
lovemysan's Avatar
gutless wonder - '02 sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 surburban 2wd LT
90 day: 19.43 mpg (US)
The airdam that didn't work
Last august I made a trip to georgia. Before I left I fabbed up this airdam. It gave 5.5" of ground clearance. It was made from 26 gauge HVAC sheet metal. The first 3 hours of the trip netted excellent results(tailwind). Upon turning south mileage plummeted. I put 750miles on it with worse than usual mileage. I did some early morning 60-30mph coast down test. The results were very close but the without the airdam I got a very light improvement. This confirmed my suspicions that it was indeed hurting performance. The airdam certainly had its advantages, the A/C worked as good as stock at highway speeds. The added high pressure on the cars nose made for excellent cooling properties(Which was nice for a trip to Georgia in august). It also just looked cool. I couldn't have gotten more looks if I was driving a hot pink pantera. It was however impossible to live with. Even the most gently graded driveway would defeat it. Gravel is the enemy of any airdam. It wouldn't last 20 minutes on an icy winter day. The presence of mind required to prevent its destruction was mentally draining. I think for proper performance in my case the airdam and belly pan must be integrated together.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
Old 04-03-2008, 10:59 PM   #2 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Did you have the full bellypan before or after the airdam?
I've had excellent results with my airdam, though without a bellypan.
I have since taken about 4" off my airdam (essentially making it a grille block) and added front and rear undertrays. I haven't had a full tank of gas through it since, but I'm interested to see the results.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 04-04-2008, 01:37 AM   #3 (permalink)
Future EV Owner
Wannabe - '05 Civic LX
90 day: 40.53 mpg (US)
lovemysan, you should enter your car in the EM Garage so that we can learn from your experience. I just entered mine.
Old 04-04-2008, 08:21 AM   #4 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 metro 4 dr HB
90 day: 66.44 mpg (US)
That was nice looking. I had a similar experience with airdams. I started quite radical with a 7" airdam. It looked interesting but rubbed alote (luckily it was made from coroplast so it held up well) and coast down tests showed a slight decrease in performance. I ended up shaving it so it was 3.5 - 4 inches tall (just enough to block most of the undercarriage components from the air flow). It looks okay, doesn't rub anymore, and the coast down test were inconclusive (showed no decrease in performance over no airdam) so I just left it on. I'm not using any kind of belly pan in the front of my car though. I may try a belly pan vs airdam once temps stay warm.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 04-04-2008, 11:44 AM   #5 (permalink)
airdam (damn!)
Great photos,and love the look of your work! I think your project fell victim to the diminishing-return/negative-return,as the depth of the airdam added a significant increase to the cars frontal area,increasing drag by a corresponding factor.Should you have had Hucho's book,you would have found that if the airdam projects below the elevation of the lowest suspension member,drag will begin to grow as a percentage of the percentage increase in frontal area.Bummer! The book is invaluable to any one considering aero modifications and can soon pay for itself in time and material saved.
Old 04-04-2008, 01:05 PM   #6 (permalink)
lovemysan's Avatar
The air dam was 1" lower than the center section of the pan. The pan actually actually declines from the bumper to suspension 3-4". Also the airdam was not level with the ground it was 5.5" in the center and roughly3.5" on the outside. I'd like to get that book but don't have $40 to spend on it. I need new motor mounts.
2002 Saturn SL
sohc + 5spd = 50mpg
Old 04-04-2008, 08:11 PM   #7 (permalink)
What's behind the lower lip of that spoiler? Does it just hang down, or is there a tangential horizontal surface that is part of the undertray? Could make a big difference.
Old 04-04-2008, 08:50 PM   #8 (permalink)
Peter
My Truck - '96 RAM 3500 Laramie
"Even the most gently graded driveway would defeat it."
I used to drive a tow truck and we had the same problem but for a different reason. If you drive up a steep grade in a tow truck while towing a car, the back of the tow truck drops and there is a risk that the car on the back will hit the road and fall off. (don't ask me how I know this) The solution is to approach any grade on an angle. Now for a speed bump this would be difficult, but where you are going into a parking lot that has a steep grade, try to go in at an angle, so only one wheel hits first.
I hope that makes sense?
Peter
Old 04-05-2008, 12:14 AM   #9 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Heynow999 offers a good suggestion. I always see lowered cars take speed bumps and driveways at an angle. Speed bumps are handled with a zigzag pattern...moving to the leftmost area of the lane, cutting sharply to the right across the bump, and straightening out in the rightmost area of the lane.
I'd lose the antenna. I'd bet you'd decrease air drag a healthy fraction of a percent.
- LostCause
Old 04-05-2008, 06:10 PM   #10 (permalink)
fabrio.'s Avatar
tigra AERO - '96 tigra
I am not surprised from your results.
with your airdam, you have added more frontal area, and because your car (with many aero mods) it is very efficient, your have gotten worse the things.
If I just remember, your car is equipped with full bellypan.
You can try to reduce central height of airdam, this, reduce the FA, and permit to pass the air under your car.
Look, the example opel calibra.
Calibra equiped with engine undercover, use an airdam tested in windtunnel.
After many tests, Opel are deliveryd an airdam shaped with raised central area, and high at the side.
look the image below:
It permit to deviate the air from wheels and the suspension arm.
I do not have any report, but in my car, I am insirated me to Opel for my front deviator
if you try it, tell us the change.
News: GM's chairman - "small cars don't work in this country" MetroMPG General Efficiency Discussion 32 11-19-2008 06:50 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Airdam or bellypan? nascarnation Aerodynamics 3 04-04-2008 01:24 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
Request for 'work in progres' thread Daox Forum News & Feedback 4 12-23-2007 10:03 PM
