Airdam made of lawn edging
... it's gonna look pretty good! It just goes low enough to cover the lowest part: the front differential. Couldn't have picked a better height for that edging. Quick and easy to make too. I'm thinking of attaching it with spring-steel clips- no drilling, and if push comes to shove, hopefully it would fall off before breaking anything.
http://i146.photobucket.com/albums/r...dam003-1-1.jpg http://i146.photobucket.com/albums/r...irdam002-1.jpg http://i146.photobucket.com/albums/r...irdam001-1.jpg Now to see if the fuel logs detect anything. P.S. Had to pull the grille block out when towing the other day- she was getting hot. |
Little bit of Redneck engineering
Anything reinforcing the lower edge in the middle and corners?
Looks good Frank.
Nothing against the blue swirly plate, but pulling it might create less turbulance. |
Very tidy, Frank. You can hardly tell that it's RNE, haha.
That is a very nice example of F series, btw, Frank.
The edging is formable with a heat gun. I even finished the cut edges on each end by forming them to match the stock dam it's attached to. |
