Old 05-15-2011, 11:19 PM   #1 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Airdam made of lawn edging
... it's gonna look pretty good! It just goes low enough to cover the lowest part: the front differential. Couldn't have picked a better height for that edging. Quick and easy to make too. I'm thinking of attaching it with spring-steel clips- no drilling, and if push comes to shove, hopefully it would fall off before breaking anything.
Now to see if the fuel logs detect anything.
P.S. Had to pull the grille block out when towing the other day- she was getting hot.
TOOQIKK (07-03-2011)
Old 05-16-2011, 12:39 AM   #2 (permalink)
Rusty Marina's Avatar
Little bit of Redneck engineering
Old 05-16-2011, 05:26 AM   #3 (permalink)
Avalon - '99 Avalon XL
90 day: 28.44 mpg (US)
Tacoma - '05 Tacoma 2wd regular cab
Pretty - '011 Sonata
Anything reinforcing the lower edge in the middle and corners?
Old 05-16-2011, 07:55 AM   #4 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Looks good Frank.
Nothing against the blue swirly plate, but pulling it might create less turbulance.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 05-16-2011, 08:33 AM   #5 (permalink)
piers.singer's Avatar
Very tidy, Frank. You can hardly tell that it's RNE, haha.
Spoken like a champion. Oh no, disaster!
Old 05-16-2011, 09:09 AM   #6 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Originally Posted by JasonG View Post
Looks good Frank.
fairly sure it's required by law...
Old 05-16-2011, 09:09 AM   #7 (permalink)
Steve - '92 Festiva
That is a very nice example of F series, btw, Frank.
Old 05-16-2011, 01:42 PM   #8 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Yes- the shape of the edging itself. It has a tubular x-section on the bottom edge that gives it more than enough rigidity, yet it's quite a light piece.
Old 05-16-2011, 01:43 PM   #9 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Looks good Frank.
That is a ram implosion plate, good for 3 mpg!
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
Cd (07-02-2011), Christ (05-16-2011)
Old 05-16-2011, 01:47 PM   #10 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Thanks. I put the stickers on myself. You are looking at the one and only vehicle I've ever bought new. I've mostly babied it but it does bear the scars of a working truck. Well, mostly it bears the scars of being in the Rust Belt. By knowing to wash inside above the rear wheel wells, though, I've been able to keep that common rust area from going bad.
The edging is formable with a heat gun. I even finished the cut edges on each end by forming them to match the stock dam it's attached to.
Christ (05-16-2011)
