Old 08-17-2008, 10:32 PM   #1 (permalink)
Meph's Avatar
240Z - '73 240Z 240Z
90 day: 34.41 mpg (US)
Alignment vs mpg
Ive always had a pull in my car to the right, not super bad (would take about4 seconds to steer off the road at highway speed)but definitely noticeable. Has anyone checked their MPG before and after a good alignment?
Old 08-18-2008, 02:32 AM   #2 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
My alignment was way off, but getting it re-aligned did not make a difference in FE. One reason could be the fact that my camber was also bad and the front tires were riding on the inner edges making a smaller contact patch with the road.
Old 08-18-2008, 03:54 AM   #3 (permalink)
Roman's Avatar
Golf D - '83 Golf GL
90 day: 42.79 mpg (US)
Here in the Netherlands all cars have by default a pull to the right. That's because when you're driving and go knockout the car will slowly go to re rights and leave the road. But 4 sec is indeed a bit to much.
NOW INTERACTIVE! Joystick controls Fry's left ear.
Old 08-18-2008, 08:32 AM   #4 (permalink)
Daily Driver - '01 Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
how is your tread wear? if your tires are wearing pretty even in the front, then i don't see it making much of a difference. if your front tires are "cupping" (especially the right-front), then they are dragging to one side when the steering wheel is straight. i can see this hurting mpg if its bad enough.
My Intro
Old 08-18-2008, 08:57 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
The farther away from 0 degrees toe in you get, the more your tires are scrubbing (and the more force it takes to move the car).
Right at 0 can translate to a bit of toe out, and any amount of toe out means it will be work just to keep the car on the road
Old 08-18-2008, 10:16 AM   #6 (permalink)
Meph's Avatar
Tires wear pretty bad on the inside after a few thousands km's far more then normal. Thanks for the inputs, ill post my change in mpg after I got an alignment done
Old 08-18-2008, 10:50 AM   #7 (permalink)
Brown Bus - '98 Sonoma X-Cab SLS
90 day: 31.37 mpg (US)
Radial tires are wound in such a way that they creep to the right by default. Woulen't want them going to the left now would we? Roads are also crowned to help with drainage - and suspensions (depending on the caster) can be sensitive to side-slope.
Meh Truck
Old 08-18-2008, 11:29 AM   #8 (permalink)
I had a right front wheel bearing problem with my Celica, that caused the car to pull right, and the alignment to be out enough to see odd tire wear (prematurely wearing of the inside edge)... after I fixed it, FE got better by about 2-3 mpg.
My thinking is this: If there's worse than normal tire wear, you are scrubbing the tire(s) and therefore wasting energy.
Old 08-18-2008, 11:38 AM   #9 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Alignment can effect fuel economy due to the "scrub" effect from improperly aligned tires.
Old 08-18-2008, 12:10 PM   #10 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
How can this be? Youve got both sides of the car, and also youve got the choice to have them mounted whitewall in or out. Only a handful of tires are directional tires.
Winter daily driver, parked most days right now
Summer daily driver
Poll: MPG before and after hypermiling peterj Hypermiling / EcoDriver's Ed 36 04-23-2009 06:16 PM
MPGuino reading MPG backwards? Helpsky? SVOboy OpenGauge / MPGuino FE computer 13 07-15-2008 09:19 AM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
Weird MPG issue. Johnny Mullet Hypermiling / EcoDriver's Ed 5 05-13-2008 08:57 AM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
