Old 04-13-2012, 03:39 AM   #1 (permalink)
MALIBU MOD - '07 chevy malibu 2LT
90 day: 29.39 mpg (US)
average avao - '09 chevy avao LT
90 day: 32.68 mpg (US)
looking for gap filling materials
I'm looking for a material to fill in the gaps between the hood, grill, headlights, and any other panel. The gaps range from 1/4" to about 1". The material needs to expand and contract, be at least semi-permanent to withstand the elements, and easy to remove if necessary. I would like to keep the stock look so the material needs to be black or be easily colored black.
I was considering some foam rubber weather stripping with a mild adhesive strip would do the trick, or I don't know if there is something like that made for automotive purposes.
I realize this sounds like I want my cake and be able to eat it too, but I love cake!
I appreciate any comments/ suggestions.
Whether you think you can or you can't, your right.
-Henry Ford
Old 04-13-2012, 09:22 AM   #2 (permalink)
I bought some stuff like that at my local NAPA retailer last year (no other parts store carried it). Much denser and better quality than weatherstripping from home improvement stores. And not as expensive as I had imagined. However, I had a choice of only two sizes, but this would be idea to get started until you figure out what works best for you.
You could maybe order some stuff on-line (Summit Racing or JC Whitney), but nothing like getting a real piece in your hand locally.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
hendgeofdeath (04-14-2012)
Old 04-13-2012, 11:37 AM   #3 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
RTV silicone sealant, maybe? I've been wondering if this would work; wrap the edge of the hood with Saran Wrap, and wet it down with some WD-40. Then run a bead of RTV along the inside of the opening. Close the hood, smooth out the bead and let it cure. Then open the hood and remove the Saran Wrap.
I haven't tried it, just a thought in my head at this point.
I think Basjoos used caulking on the Aerocivic, cut with a razor blade after it cured.
-Terry
Old 04-13-2012, 11:52 AM   #4 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I used a chunk of black pipe insulation to seal between my hood and bumper (~1"). It comes in different sizes and is really cheap (~$1 for an 8 ft piece). It comes in different sizes, but I dont know if you can something small enought to do the 1/4" gaps.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 04-13-2012, 01:24 PM   #5 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I second Diesel Dave's suggestion with the pipe insulating foam.You could cut the insulating pipe length ways using a improvised guide to cut straight and get the width you want.
Save gas
Old 04-13-2012, 06:03 PM   #6 (permalink)
foam rope caulk backer
At hardware stores and home improvement stores,in the weatherstrip section,you'll find foam rubber rope which is designed to go into large cracks as a backer for caulk,made of material, quite like pipe insulation.It comes in a roll in a couple different diameters,is that same dark gray color and you may be able to just push it into the gaps.
Old 04-13-2012, 11:44 PM   #7 (permalink)
I think I will look into NAPA for this stuff. I didn't realize there was one near me. (I live in ypsilanti) didn't find one close to me on Google search. where is it at?
-Henry Ford
Old 04-14-2012, 12:34 AM   #8 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Caulking actually comes in black. It comes in clear as well, but looks non factory if you seal gaps using the clear ( ends up looking like mucous )
As you apply it you can use a wet rag to smooth it down.
This takes mere seconds to do and makes the mod look factory.
Using a razor after the caulking has cured is about a hundred times more difficult than using a wet rag and results in rough edges and possibly sliced fingers and scratched paint.
If you leave the caulking oozing out of the gaps, you not only make the car look bad, but you cancel out any benefits you get from sealing the gaps in the first place.
Just my opinion, buy I think the main thing that makes the AeroCivic look rough around the edges is the unsmoothed caulking.
Cmon Basjoos you know it would make the car look SO much better !
Old 04-14-2012, 09:19 AM   #9 (permalink)
Can I haz Coroplast plz
Regenerit's Avatar
11 Genesis Coupe - '11 Hyundai Genesis Coupe 2.0T
Last 3: 20.91 mpg (US)
I think Basjoos after realizing his car was going to look ugly no matter what and maybe in a rush to finish decided that making every little detail perfect would take up too much time and so threw beauty into the wind and got his car done quick. Let's not forget his aerocivic has been fully modded for the most part for nearly 4 years now.
Old 04-14-2012, 09:05 PM   #10 (permalink)
NAPA is on "Industrial" in Ann Arbor, between Stadium and Eisenhower.
Pretty good place, they had the front drop links for my S-10 in stock and even told me how to install them.
Chin Spoiler:
Roof Wing
