If you under drive the alternator (put a larger pully on the alt or a small pully on the crank) that should keep the alt from putting out enough power to fry its self or install a charge limiter.
Originally Posted by Ladogaboy
Lithium batteries have a max DoD of about 80%, meaning you can use 80% of.
The problem with that is LiFePO4 batteries have a very low internal resistance and there for have an affinity for power when they are discharged.
If you were to discharge them deeply then they would soak up every possible amp if you flipped the alternator back on unless you installed a charge limiter.
LiFePO4 batteries make for a very expensive deep cycle battery.
Ethere way if you went to charge a very hungry and very large battery from your alternator it may burn up the battery charge wire.
My truck burned up a 12ga wire with normal glow plug cycling and engine cranking, so I up graded the battery wire to 8ga with soldered ends.
