Register
Now
Reply
Old 08-14-2008, 06:29 AM   #1 (permalink)
Roman's Avatar
Suzuki Swift - '92 Swift GL
90 day: 41.7 mpg (US)
Alternatife for alternator.
First of all: What will removing the alternater doing for FE?
I was thinking of removing the alternator and install something else. I've seen someone with 2 accu's and a solar pannel. But i think that's not efficient enough. Also got an garage so... no sun there
Than i thought. What's in the car that's useless... heat Now we get rid of the heat whit the radiator in front. But we also could use that heat. Heat equals energie. So i thought again (not getting an headake) about somethink like a sterling engine. I know sterling engine will only get 50% of the Carnot-Faktor but could it be enough for an alternator.
Also the heat from the exhaust could be used .
Good thing is that is don't have an A/C. Bad thing is that i always hear music
But were to find a small sterling engine?
For testing i thougt about to let the radio run fisrt on the stering and when that's doing good i will use it for the whole car.
Someone did this before? Or someone have an other idea how to use the heat for making power?
/edit somebody tried something whit a Thermogenerator? Just peltier-elements the other way. http://en.wikipedia.org/wiki/Thermogenerator It's called Seebeck-Effect. Transforming heat to energie. But don't know if i simple can use Peltier-elements.
NOW INTERACTIVE! Joystick controls Fry's left ear.
Swift 1.0 GL
Old 08-14-2008, 03:16 PM   #2 (permalink)
Captain Slow
Blackfly - '98 Metro
90 day: 78.69 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 128.28 mpg (US)
The alternator is a significant load on a small engine. Removing it can be very good for fuel economy (~10% improvement isn't uncommon).
Have a look through these search results: lots of discussion of alternatives to using an alternator, including solar, peletier, etc...
alternator - EcoModder Google Search
Latest test: Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete)
Latest mod project: designing/building front wheel skirts (Geo Metro)
Old 08-15-2008, 09:25 AM   #3 (permalink)
Roman's Avatar
I did my homework and found this topic.
I think the Tiger option should be the best, but i think it wil be expensife. But number 2 is like a good idea. Just use a bigger diameter to reduce rotations and by this better FE. But how much % wil it give? And how to make it?
Swift 1.0 GL
Old 08-25-2008, 08:26 AM   #4 (permalink)
Roman's Avatar
I just came on a site called heat2power.net and found that there are some manufactures (like BMW) are making (testing) some kind of heat 2 power stuff. Like from the exhaust.
Now i was thinking about this:
So a smal pump is puming some liquid around. This liquid getting heated by the exaust pipe til reached boilpoint. Than it's going to a trubine and finally in a condenser to get liquid again. And the turbine just feeds the alternator.
This should be makeble. I only need some parts like a turbine and a condenser. A condenser is not hard to get, but where can i find a turbine?
Swift 1.0 GL
Old 08-25-2008, 08:51 AM   #5 (permalink)
4OVER4 - '85 Starion ESi
90 day: 24.97 mpg (US)
Auto - '87 Starion LE
90 day: 23.65 mpg (US)
Originally Posted by Roman View Post
...but where can i find a turbine?
Use the exhaust-side of a small turbo?
Old 08-25-2008, 08:59 AM   #6 (permalink)
Roman's Avatar
Hmmmm where to find one for cheap. The most turbo's i see are 200-400 euro and that's a little too much for this experiment. I don't want to spent a lot of money in something what maybe not working.
Swift 1.0 GL
Old 08-25-2008, 11:41 AM   #7 (permalink)
Blue - '-1823 P/U
find one that needs rebuilt
Old 08-25-2008, 03:06 PM   #8 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
junkyard a small stock turbo. No need to buy new.
Reply
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
