08-24-2009, 08:36 PM
#11 (permalink)
chop suey
He's either put in a desmodromic valvetrain, or the idle speed is also the redline.
08-24-2009, 08:57 PM
#12 (permalink)
needs more cowbell
Originally Posted by MadisonMPG
I will post it, but I disagree with it. The spring pushes back just as hard as you pushed it down.
.......here it is
That didn't work.
To some extent, yes, you can measure the torque at different degrees and on the "downhill" side of a lobe you will get about the same force pushing on your torque wrench as you had on the same spot going uphill.
BUT, the valves themselves are reciprocating, and have mass, so that the faster you spin the camshaft, the more force it takes to jerk the valve open, which is lost energy. As well I suspect that the springs do not return as much energy at higher speeds as they have to use some energy to accelerate the valve in the closed direction.
08-24-2009, 09:10 PM
#13 (permalink)
alternating valve engine
why are some of you guys so nasty and negitive ? You havent even read the patent description write up yet? jim whitmer 405 751 4521 j.whitmer@cox .net there is a saying as follows......contemp prior to investigation will leave a man in everlasting ignorance....If you dont want to know about my patented engine....then leave me alone...I'm the one who has the 4 million dollars coming to develope it ...not you!
08-24-2009, 09:13 PM
#14 (permalink)
chop suey
Well the first red flag was "double or more the economy".
It didn't get any better after that.
08-24-2009, 09:51 PM
#15 (permalink)
Moderate your Moderation.
Originally Posted by Frank Lee
I've already made my decision.
That energy used to compress springs, minus friction, is largely recovered when the springs decompress.
I don't think this is correct, Frank - the valve stems don't act on the cam to keep it in motion, the springs only act as a way to keep the valves seated and closed unless the cam is acting on them. This is part of the reason that solenoid engines are so much more efficient (not by any means 50%) than cam driven engines.
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux ętre heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
08-24-2009, 09:55 PM
#16 (permalink)
needs more cowbell
I am again asking you a direct question, what is the patent number?
08-24-2009, 10:13 PM
#17 (permalink)
You are asking me a direct question ? I'll give you a direct answer...none of your business...now leave me alone....I got on this foreum to share some things, not ask for opinions or request debates.....leave me alone...just as soon as I can figure out how to unsubscribe to this cult I'll do so.....
08-24-2009, 10:16 PM
#18 (permalink)
thinking i might have to convert my engine
but think about it, going from 150lb to 15lb is only a 90% reduction. what a waste!!!
thats why 2 strokes have the best powerbands, no valve springs...
in addition, i found this product to further enhance my efficiency and performance Piston Return Spring - $14.99 : KaleCoAuto, Hard to find automotive items!
KaleCoAuto piston return springs FORCE the pistons back into the motor, no longer relying on gravity! This effectively increases your revs, horsepower, and peak torque!
08-24-2009, 11:37 PM
#19 (permalink)
Facts Jim, facts.
08-24-2009, 11:43 PM
#20 (permalink)
That's thinkin' wif yer dipstick, Jimmy!
Sorry to see you go... when you man up and come back, be sure to PM me, so I don't miss the thread.
