Old 08-24-2009, 11:52 PM   #21 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
White Pony - '07 Mustang V6 Premium Coupe
Team Ford
90 day: 29.22 mpg (US)
Big Red - '89 F-250 4WD Custom
90 day: 15.27 mpg (US)
Jim, you're not related to Dave, are you?
I didn't think so.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Old 08-25-2009, 12:59 AM   #22 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I tried to do some figuring on the losses to the reciprocating mass of the valves, not sure how good I did but it came out to about .05 hp at 5000 rpm on a v8.
Pretty sure that doesn't account for doubling mpg.
And if that is $4mil in tax money, Jim damn well should be discussing it in public, IMHO. I'll make it my business.
Old 08-25-2009, 01:20 AM   #23 (permalink)
saturn - '99 sc1
90 day: 35.67 mpg (US)
think i'll wait for a large scale version of these anyway
Camless 4 Stroke Cycle I.C. Engines with Solenoid Operated Valves.
index
Old 08-25-2009, 01:25 AM   #24 (permalink)
dcb
needs more cowbell
dcb's Avatar
Sure, if the valves take that little energy (comparatively) to open and close then let a computer control them and ditch the throttle.
Old 08-25-2009, 01:28 AM   #25 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Figured I'd post this just for fun. Evidently it's for sale "REAL CHEAP"
http://ecomodder.com/forum/attachmen...1&d=1251174442
Good reading for any cult member
Old 08-25-2009, 01:33 AM   #26 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Common Misconception:
Many people mistakenly think that using higher seat pressures causes a reduction in the horsepower delivered to the flywheel because higher seat pressures (and also higher spring rates required for high performance) require horsepower to compress the springs. This thinking is simply incomplete! For every valve that is opening and its valve spring being compressed, another valve is closing and its valve spring is expanding. This expansion returns the energy to the valve train and the engine. This results in a net power loss of "0" hp. Many engineering texts refer to this as the "regenerative characteristic" of the valve train. Recent tests at Crane have shown no horsepower loss on a hydraulic roller equipped engine when changing the seat pressure from 135# to 165#. Power actually improved significantly at top end, probably due to better control of the relatively heavy valves in the engine.
Crane Cams
The Crane Cam boys have forgotten more about valvetrains than the rest of us will ever know.
Old 08-25-2009, 01:42 AM   #27 (permalink)
dcb
needs more cowbell
dcb's Avatar
unh... the patent number mentioned in that pdf is for something completely different, from like 1979?!?
Temperature actuated foundation ventilator - Patent 4290554
Old 08-25-2009, 02:10 AM   #28 (permalink)
saturn - '99 sc1
The Whitmer 8 Cycle Engine uses only only one of the existing two intake valves opening and closing during the first two cycles and only only one of the existing two exhaust valves opening and closing during the next two cycles
so you leave an intake valve open for 2cycles.... wouldnt the second cycle be the piston moving up, pushing the air back out?
Old 08-25-2009, 02:12 AM   #29 (permalink)
Dartmouth 2010
SVOboy's Avatar
I think the concept is just that of a 4-cycle VTEC-E system except it alternates which valve is open, no that they're open longer.
Old 08-25-2009, 02:21 AM   #30 (permalink)
saturn - '99 sc1
but then the individual valve would have to move just as fast, but only every other time
i thought he was trying to move the valves at half speed
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
Restore oil additive... suspectnumber961 Success Stories 43 05-14-2010 04:40 PM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 03:32 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
