Old 09-20-2014, 08:32 PM   #21 (permalink)
Traverse 2LT FWD - '12 Chevrolet Traverse 2LT
90 day: 21.2 mpg (US)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 40.44 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 127.32 mpg (US)
The problem with the hair dryer is that it is very indirect heat. You're counting on the hot air to heat the block but air is very easily heated and cooled, not much heat capacity.
Old 09-21-2014, 09:11 PM   #22 (permalink)
XYZ
You can use an external heater, but a hair dryer is about 50 to 100 times too small.
If you could direct the output of a small furnace under the hood that would do it.
Or get a block heater.
Indeed. You are just wasting heat energy in blowing cold air around and trying to heat something else. Electricity doesn't come free. It's a waste of money.
To add to the "small furnace" concept: You could build a fire underneath the car and BBQ the engine.
Bring hot dogs and hamburgers. Have a winter picnic. Hope that the fuel lines don't ignite, because you might burn your weenie.
(Disclaimer: this is only an attempt at humor. "Remember, kids, "don't try this at home"!)
Old 09-21-2014, 09:24 PM   #23 (permalink)
I used a hair dryer to successful start a old diesel vw. I stuck the end of the hair dryer into the air intake and let it sit for 45 minutes. The tube, part of the intake and head were warm.
I think you are better with the heating pad to oil pan vs just an air to air heat exchanger.
Old 03-10-2018, 05:21 PM   #24 (permalink)
Look what I found on AliExpress
https://www.aliexpress.com/item/3284...846125579.html
Would this kind of block heater be of any use or is ti junk?
Old 03-11-2018, 05:53 AM   #25 (permalink)
Renault owner
Fingie's Avatar
Tegybi - '97 Renault Twingo 1.2 Mpi
90 day: 43.07 mpg (US)
why does it have a Transformers logo?
electric and obscure chinese stuff- would not put anywhere flammable
If you don't make any mistakes in your life,
life itself will be a f*ckup.
it's not your fault, Renault
The Following User Says Thank You to Fingie For This Useful Post:
RedDevil (03-11-2018)
Old 03-11-2018, 05:57 AM   #26 (permalink)
Renault owner
Fingie's Avatar
in finland, we heat the engines of tractors and log harvesters with gas.
Name:	heater tractor.jpg
just hook up the quick connectors and start heatin'
Old 03-11-2018, 06:16 AM   #27 (permalink)
Unfortunately I do not live in Finland at the moment.
I am currently in istanbul which is very very urban, i doubt i would be able to hookup propane to the car in a closed garage.
How about a respectable version of the above device?
Old 03-11-2018, 10:40 PM   #28 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 43.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 34.87 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 36.8 mpg (US)
Attachment 23660
This is similar to electric race car heaters.
https://pitstopusa.com/i-23928869-cr...-hose-kit.html
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
