Old 08-23-2008, 04:03 PM   #21 (permalink)
If you could magically perform back-to-back tests,simultaneously,you could easily measure the difference.----------- One thing to consider.The alternator load may have been a design criteria for the cars powerplant design and may effect it's BSFC.----------------------------- By arbitrarily lowering the "load" on the engine,you could actually move it into a regime of lower efficiency.-----------------------------------------------I lost an alternator in Amarillo,Texas,in the CRX.It was going to be two days to get a part.I went to Walmart,bought a spare battery and battery charger.I drove,in two days,to Phoenix,Arizona,running constant-loss off the battery I charged in the motel room.I'd topped off the tank in Amarillo,and by Phoenix,I'd showed no measurable gain in MPG.------------------------------------ I have also purposefully removed the alternator belt and conducted mpg tests,and never showed any measureable difference.--------------------------- The CRX alt drops field exitation during acceleration,then resumes with manifold vacuum increase.--------------------- Also,cheap,adjustable,normally-closed vacuum switches can be adjusted to open-circuit the field,while under acceleration.----------------------- I've found the manufacturers systems so efficient,reliable and of little load,I no longer consider modifications to them for a daily driver.Just my opinion.
Old 09-01-2008, 12:13 PM   #22 (permalink)
Tracy - '00 corsa
here is my system. i have 144v of NiMH batteries hooked up to the power inlet side of a power supply, (where you would normally plug it into the mains). you can put DC into these even though they usually work on AC. the other side it comes out at 15.5v. i selected 15.5v with the trimmer pot because it was closeest to 14.5v that the alternator tops off at yet still gave enough voltage difference to get a decent amount of power. the power supply is from ebay and is for a computer or something? its rated at 350watts. i have a watts up meter in the line to tell me whats going on. i didn't drill through the fire wall yet i just tapped into the cigarette lighter port.
the car drew about 130watts, 8amps whenever the engine was running. when full lights were switched on this went up to 170watts. the voltage settled at 15.2v. weird thing was i couldn't EOC with it plugged in. the engine wouldn't switch off. this is why i will probably wire it straight to the battery.
i was pretty pleased with this first attempt. ill test it at the weekend when i need to drive somewhere.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 09-01-2008, 12:35 PM   #23 (permalink)
Tracy - '00 corsa
that should be 4.5% saving in fuel @ 55mph according to that handy spread sheet i found on this site. -who posted that?
17% saving at 35mph. load didn't seem to change with speed.
Old 09-04-2008, 08:32 PM   #24 (permalink)
Tracy - '00 corsa
ok ive installed it straight to the battery now so i should be able to EOC again. im doing some miles at the weekend so i should be able to test it then.
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 08:50 AM
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 21 01-06-2010 06:54 PM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 02:05 AM
Series Motor - Speed vs Torque TomEV Fossil Fuel Free 3 03-02-2008 01:27 PM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 10:26 PM
