Old 06-08-2010, 10:31 AM   #1 (permalink)
Aspiring EcoModder
Eggy - '99 SL2
90 day: 43.7 mpg (US)
Alternator disable switch -- how much MPG improvement?
I know a few of you guys have installed a alternator disable switch. Just trying to get an idea of how much that will improve MPG (actual number or %). A "guesstimate" is fine since I'm still months away from completing all my mods.
My daily round trip commute with my 99 Saturn SL2 automatic is 64 miles (56 highway, 8 city) with some construction and traffic.
Old 06-08-2010, 10:32 AM   #2 (permalink)
Aspiring EcoModder
Eggy - '99 SL2
Forgot to mention that I did read the second half of DOAX's Paseo thread which includes the alternator switch.
Old 06-08-2010, 10:49 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Darin (metrompg) tested this a while back. He saw a 10% improvement at steady state cruising.
Test: Alternator vs. no alternator = 10% MPG gain @ 70 km/h
Old 06-08-2010, 10:58 AM   #4 (permalink)
Aspiring EcoModder
Eggy - '99 SL2
Thanks Daox
Old 06-08-2010, 10:59 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
technically, Darin had removed the belt from the alternator so that it wasn't even turning. There would be less gains from just turning off the field. And it was a metro.
Old 06-08-2010, 12:02 PM   #6 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 42.23 mpg (US)
I did it on my 94 Toyota PickUp. I was not able to measure any change, I don't have a computer and tank to tank fillups with variations in temp/load didn't see any changes.
I do know I can feel a change in acceleration up a hill or a quick left turn in traffic with it off. Maybe I'm just using the switch in improve performance not improving gas mileage.
Don't get discouraged. I think if I had a scanguage or similiar and did A-B-A testing I would see a difference. Removing belt gets 10% so I would expect field switch at 5% or so.
Old 06-08-2010, 05:12 PM   #7 (permalink)
I have to start over?
Big inefficient truck - '94 Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Civic DX Hatchback
I have a field switch, so when I get my MPGuino, I will be able to tell you a % gain. I won't be able to say MPG improvement, because I won't have it calibrated by then.
Sometimes, however, when I have the alternator off, the engine feels funny. Like the throttle is closing partway. It goes away when I turn the alternator back on. I suspect that it is the ignition getting less powerful with the low battery volts.
Old 06-08-2010, 09:04 PM   #8 (permalink)
Aspiring EcoModder
Eggy - '99 SL2
This alternator disable switch is one of the more extreme mods/tactics that I may end up not doing ... in the same boat as power steering pump delete and turning off the engine (during P&G). Maybe after exhausting the aero mods, I might reconsider.
Thanks for the input, though.
Old 06-09-2010, 09:04 AM   #9 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Were you also recharging the battery from an external power source?
Old 06-10-2010, 09:44 AM   #10 (permalink)
busypaws: saw you answered my question in another thread:
I get about 20-30 miles before the radio starts lossing power then I know to turn alternator back on.
If you're not using an external power source to re-charge the battery, that explains why you're not seeing any fuel economy benefit.
Some vehicles use smart alternator control to eke out a few percent savings, but mostly by maintaining a minimum voltage under accel/cruise, and boosting alternator output under engine over-run and braking conditions.
Frank Lee (06-10-2010)
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 38 03-29-2012 04:53 PM
free OBD2 software with MPG calc whitewiz Instrumentation 6 02-18-2012 11:31 AM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
