Old 08-27-2010, 12:34 PM   #1 (permalink)
Wiki Writer
bugler - '91 626
90 day: 35.89 mpg (US)
alternator switch modification in mod list?
Hi All,
I had an idea about installing a switch for the alternator so that I could turn it off during normal driving and enable the alternator when breaking or when the battery voltage gets low.
I had a search for this idea and I have seen a few threads around about others that have done it but I haven’t seen anyone say it has worked for them or not.
(I may not seen all threads on the topic though)
So the question to the group is, has anyone performed this mod and had success in helping their efficiency and was it done with the stock car battery or was a deep cycle used.
Ideally I would like to put this mod in the wiki mod list but I would like to hear at least 1 person getting good results before I put it up.
Old 08-27-2010, 12:55 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'm pretty sure a couple guys have done it. The main problem is you can only use the alternator while engine braking since the engine must be spinning to spin the alternator. A good ecodriver minimizes brake use so much that this really doesn't allow for a ton of regen. Even if you did move the alternator to a driveshaft or something, the braking power it would provide is next to nothing.
In order to disable the alternator for any prolonged amount of time, you need a deep cycle battery. A starting battery will die very quickly when deeply cycled.
Cycle Efficiency Mod List alohaspirit Motorcycles / Scooters 54 03-23-2011 09:29 PM
[Mod list discussion] Wiki up and running. Thread for suggestions to main mod list saand Forum News & Feedback 26 10-13-2010 05:19 PM
Making use of the Wiki for modification / hypermiling info saand Forum News & Feedback 40 09-06-2010 08:23 AM
What are your 2008 mod goals / wish list? MetroMPG EcoModding Central 45 01-02-2009 01:57 AM
