Welcome to ecomodder.
Originally Posted by ryankalel
I have a 2000 TDI Beetle with 240K miles.
I get on average 43-46 mpg.
Is that a Beetle with a manual transmission ?
As most manufacturers, VW have some lightweight manual gearbox oil - lighter than what they previously used anyway.
If your car is due for a gearbox oil change, ask the dealer for it (and ask about its suitability) if they're not already putting that oil in it.
The lightest weight engine oil that's allowed for in the environment you run the car, will also give a small gain.
The manufacturers have put some research into this, use it to your advantage
On the Volvo, I've swapped the gearbox oil for a compatible lighter weight oil after 90,000 miles and the difference can definitely be felt - smoother shifting and MPG are better than they used to be.
I drive 115 miles to work one way, 230 round trip. I live in Southeastern Utah and work in Southwestern Utah.
Wow, that's one serious commute !
Anyways, I start out at 4700ft and over 45 miles work my way up to 7100 feet and then back down to 6800ft as my final destination...and then the reverse when I go home.
Don't use cruise control on the way up or down.
Up
With these kind of elevation differences you're probably seeing some good length climbs ?
If driving with load (DWL / target driving) would probably see you slow down considerably, use a steady throttle.
(see the hypermiling tips at
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com , it's a good way down the page.)
Shed some speed when you can quickly regain it after the crest.
Do you have a fuel economy display in the car ?
You could experiment a bit using different speeds on the climb to see what suits the car best.
On steep hills, it's worth experimenting with different gears as well.
Down.
If the hills are not too steep you could put it in neutral and coast downhill.
My car will maintain 60-65 mph on 5 to 6 % gradients, in neutral
(Extreme hypermilers will even shut down the engine - but you'd loose power-steering and more importantly, the power assisted brakes.)
If the hills are steeper so you need braking, let go of the throttle while in gear and use the engine for braking - if you don't already.
If it still picks up too much speed, brake (by foot) and change down.
In gear but without giving it any throttle, it won't consume any fuel.
Pick up extra speed on the downhill - as much as allowed or what you feel comfy with - if it's followed right away by a climb.
Are you using any of these techniques ?
It is a beetle and does have some bad aerodynamics, I am thinking about an "Ernie" Wing.....
Or you could find some inspiration here :
VW Beetle TDI Kammback
Kamm-backs have been found to improve mpg on a range of vehicles.
Dieselbeetle's one-off improvement is too much for the modification he made, but you should still see some notable gain - especially as the Beetle isn't too aerodynamic at the rear.
but would this altitude and the multitude of hills decrease my mpg that much?
The altitude also means thinner air, and less air resistance.
Diesels work on an excess of air, and I've never had any troubles with power or mpg while going thru and over the Alps in a diesel.
(A3 TDi, beating 50 mpg even without any effort at serious hypermiling).
You lose some MPG uphill, but can recover a fair bit downhill.
Roads are quite rough in some spots as well.
That's not helping either I'm afraid, but there's little to be done about it.
