Old 04-27-2017, 02:45 AM   #11 (permalink)
Well, half the length times the average displacement: 25% of 4lb.
Wait a minute — Less rotational inertia. Good 60ft times but poorer pulse and glide.
Fingie (04-27-2017)
Old 04-27-2017, 09:45 AM   #12 (permalink)
I originally purchased the 1LE drive shaft during my go fast days.
The real economic advantage will be from being able to grease the U-joints and not shelling out a U-joint on a road trip and/or having to go back to the drive shaft shop to spend another $100+ on a U-joint replacement in 50,000 to 100,000 miles.
The weight savings is fairly minimal. It was originally a go fast part.
I don't do the pulse and glide, if anything I will use EOC.
The rear axle on camaros, firebirds, trans am cars were all solid axle from 1967 to 2002, I don't know about the new 5th gen camaro. So that would make the axle partially sprung weight and 100% rotating weight.
There is an even lighter 4th Gen aluminum drive shaft but I have found they tend to fail in performance applications, the older 1LE aluminum drive shafts off a 3rd Gen is the one to have.
freebeard (04-27-2017)
Old 04-27-2017, 02:56 PM   #13 (permalink)
Primer is still paint!
ChopStix's Avatar
I'm no expert, but I would think that it would take less power to turn the aluminum at the same speed as a steel one, which should have a tiny mpg benefit. I'm not saying just that one change would equal 1 mpg. But maybe if it was combined with some other mods it might show a measurable benefit.
Old 04-27-2017, 09:44 PM   #14 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
It will take less power to accelerate a lighter mass. Keeping it spinning at the same speed there will be no difference between the two. His benefits will therefore be noticed more on take-off and/or stop and go traffic.
The Following User Says Thank You to Stubby79 For This Useful Post:
jamesqf (04-28-2017)
Old 04-28-2017, 09:37 PM   #15 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Keep in mind that the driveshaft spins on a very short radius, so the inertia savings won't be anything like if you saved the same amount of weight from your tyres.
Old 04-28-2017, 11:05 PM   #16 (permalink)
The drive shaft also spins exactly 3.73 times faster than the wheels.
firebird, weight reduction
