Old 09-14-2008, 09:09 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Ok, married the meter to a MPGuino for a road test, piece of balsa/hot glue, my fave
OBSERVATIONS:
1. The refresh rate of 1/2 second makes the meter seem very un-analog. While having a refresh rate works well with an LCD (gives you a chance to read it), the analog gauge should probably be updated with every injector pulse and the average 1/2 second of speed.
2. It needs a backlight.
3. It was a bit bouncy with the road, one of those aftermarket tachs might make a better in-car meter for this sort of thing (might even have a backlight).
So room for improvement certainly, and an instant mpg without a trip mpg is of dubious value unless you are a complete hiway star. But it is certainly a doable thing with very little hardware.
Old 09-19-2008, 11:38 AM   #12 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
Multi-Meter able?
That's really cool! Would this be the type of thing you could make it a "multimeter", and have a bunch of different things able to be displayed by simply moving a switch/dial? Ex, Instant MPG, Current MPG, and RPM and Gallons Per Hour on a Four way switch. You may have to make a quite complex display depending on how many things you could switch between and what those things would be, but it would be cool!
40 mpg last night wagonman76 Success Stories 7 03-11-2012 03:12 PM
Poll: MPG before and after hypermiling peterj Hypermiling / EcoDriver's Ed 36 04-23-2009 06:16 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
My fuel meter - first results... JohnnyGrey Instrumentation 8 05-04-2008 10:35 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
