So yesterday I was @ idle... doing mainly web research on some dream list things I'm planning to do to the metro in the not so near future... Also reading some of the endless posts here dealing with all kinds of stuff... aero stuff, electrical stuff, and what not... and interestingly enough there is one project mod that I've had in mind for some time that I don't think I've seen anyone write about or do yet... but haven't read all the posts either... so I'll leave that alone for now until I'm actually ready to do it
But got tired of research, and since my block is out, and I've done just about everything else to body that I'm going to do to the car at this phase... I was only left with basically two tings I could do, rebuild the trany and drop the gas tank.
So last night I opted for the easier of the two... I dropped the gas tank to inspect internal condition of tank and pump, energized & tested the pump, ohmed out the level sending unit. All was OK! Did not install it last night because I wanted to fetch a strainer and tank gasket... But today I couldn't find one locally and they were to expensive to order anyways. I just cleaned my strainer and reused tank gasket. While I was there I inspect all my fuel and evap hose sections and they were all amazingly in great shape. So I put the tank back in today w/ new fuel filter.
With the tank back in place I set out to rebuild my trany...
But I ran into two problems... and one dilemma:
1- my harbor freight press
(which works great for just about everything else I tinker with) believe it or not will not allow for the dive gearing to fit, plus my plates are to thick... and after a few hours of messing around and modifying stuff I only was able to remove only some of the gears... So decided I better let them be before I damaged them.
I have access to better tooling and plates at my work place, so can do them later in the week if I decide to go that route, not a big deal, but it was very disappointing
and a big time waster.
2- while taking the trany case halves apart I was abruptly reminded of the fact that the transmission had a cracked bolt ear on the bottom, where apparently the previous parts donor car driver had trampled over something... either way, I remembered that it did leak during the meager three weeks it ran. So that is an issue that will
HAVE to be addressed if I decide to put it back together. I have multiple auto tranys inside the parts car, but of course they have to be different... so no point there.
The other dilemma was that I did not know for sure what my final gear ratio was... so I counted teeth today several times and yes I have 4.10... I knew I was going to rebuild the trany so I have been searching for a 3.52 ring & shaft set for some time now w/o any success... and didn't really want to buy another transmission. But it seems I might have to.
Since I can't weld aluminum I would have to take the case to a machinist I've worked with many times in the past... that wouldn't cost me much, and if I was to find a 3.52 combo for cheap, then I could go that route much more cost effectively... but I cant seem to find them.
So I'm guessing my best bet if to buy a 3.52 trany, and use my rebuild kit on it instead.. What you guys think?
Any one here have a good 3.52 ring and shaft set for sale?
Or maybe you want to sell me a good 3.52 trany?
