Old 01-14-2008, 12:53 AM   #11 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Think in terms of % of size
the alternator on any vehicle requires ~ 1hp to operate, even when electrically idle
sooo
300hp - 1hp = 0.33%
49hp - 1hp = 2.00%
Bigger difference in the smaller engine.
I'll shut-up now. S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 01-14-2008, 01:07 AM   #12 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I don't think peak hp is where it matters.
It takes approximately 6 hp to drive my car @ 40 mph on a level road. Regardless of whether that 6 hp is coming from a 3-pot capable of 49 max. hp or a V8 capable of 300, it still only needs to burn enough fuel to make 6 hp. So if you remove the hypothetical 1 hp burden of the charging system, you've just reduced power requirements by 1/6th for both motors.
The fuel savings of doing that won't scale exactly of course, due to the extra power required to overcome internal friction in the V8, and their different BSFC profiles & how they respond to changing load. But the effect definitely won't be proportional to the peak power of each mill.
Old 01-14-2008, 10:45 AM   #13 (permalink)
Silver Bullet - '02 Golf TDi
There are significant caveats, however.
Ah, the truth in advertising...
Nice write-up, BTW.
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
Old 01-14-2008, 11:40 AM   #14 (permalink)
Lurking footless halls
Silveredwings's Avatar
Orient Blue - '02 325Ci Convertible
From a (now old) press rel: http://www.bmwreport.com/bmwmininews...w-5-series.asp
Brake-energy regeneration is new to the 5 Series, which recycles previously lost energy by using a smart alternator and special battery. Whereas a conventional alternator constantly draws energy from the engine, the smart alternator only does so when the battery needs it — as well, engine energy generated while braking or descending a hill goes to charge the battery. This set-up achieves an overall three-percent improvement in fuel economy.
The 1-series is getting this too.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
