Old 06-22-2011, 09:09 PM   #1 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Another Pickup Aerolid
Many guys have proposed some variant of the "fastback" sloping down at various angles. Some seem to work better (in reducing drag) than others but all have the same problem: They restrict vision out the rear window.
Here's another idea.
Currently my truck is running around with a A.R.E. hard tonneau. Big-timeflow separtion but I see out of it nicely.
What I am thinking about is a series of flat plates, stepping down trying to keep the flow attached at a ten degree angle. I should be able to see out OK.
What do you think?
The tonneau
Two plates with no duckbill
Two plates with duckbill
Three plates with duckbill
I'm not too sure my duckbill is doing much for me. It is 18 inches long and drops 3 inches.
Big-time thanks to Carlos for his help with this.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 06-22-2011, 09:13 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Well it is dangerous to venture into armchair aerodynamics but I'm gonna give it a shot anyway: I think when we "break" a rear slope then re-attach thus trapping a vortice, the vortice really needs to be trapped so it sits there "rolling". If there is flow through that region I'm guessing it won't allow a trapped vortice to form. I think if flow comes in through the sides and goes out the back that yes, the flow down the back could be nice. The "but" is the same thing I've said about ducts: now you have internal and external flow drag.
And then there is the ever-present cross-wind flow...
If I EVER get around to finishing my aerolid I am going to incorporate a rear window treatment as the Chrysler PNGV car has.
Old 06-23-2011, 01:50 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
90 day: 51.68 mpg (US)
Frank makes a good point. Flow Illustrator is only in 2-D cross-section. A vehicle moves through the air in 3-D. Do we assume that the sides of this cap are solid like Bondo's hinged aerocap, with flat plates instead of a hatch? I sure would like to see someone build and test a version of this idea.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
Old 06-24-2011, 06:48 PM   #4 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
I rather liked the earlier idea of yours of a rear cover similar to the Camaro/Firebird rear window "slats" as a visibility "solution".
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 06-24-2011, 07:31 PM   #5 (permalink)
Big Dave's Avatar
Talking about end conditions is little premature until I get a section I like. It looks like the duckbill+3 plates keeps the flow attached the best.
Probably the aftmost plate will have solid sheet metal supports on the ends (sides?) You can’t see under that plate anyway.
The intermediate plate (or plates) will probably be supported by struts. At first just threaded rod til I can work out angles and heights. The whole point is to have some visibility to the rear and to the quarters.
The duckbill will get a tapered side support.
The duckbill worries me. In the sims the duckbill does not even begin to turn the flow and we get separation.
4" Slam
