Old 10-14-2012, 08:48 PM   #281 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.68 mpg (US)
BZP T-100 current (2013) - '98 T-100 SR5
90 day: 20.61 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Finally figured a simpler way to securing the access doors and the gap cover instead of using the bungee cords which seemed to git in the way when deploying/securing the cab cover. I just use an eye bolt on the top just like the bottom!
Now I don't have to worry about the gap cover popping open like an air brake/spoiler when driving down the road. I still have to trim the bottom of the bolt.
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (10-17-2012), ECONORAM (01-07-2013), slowmover (10-15-2012)
Old 10-17-2012, 12:38 PM   #282 (permalink)
HyperMileQC's Avatar
Commute Bike - '90 Hustler
90 day: 1276.01 mpg (US)
Trollinsight - '00 Insight
90 day: 100 mpg (US)
Send a message via MSN to HyperMileQC
I don't know if this has been asked before, but do you plan on doing rear wheel skirts? If not already done.
Anyway, nice job with the bed cap cover. I like the way you have done it. Seems like your MPG's are higher too .
EDIT : You should post a pic of the rear wheel skirts in this thread!
Trollinsight Modding Thread
Best Tank : -- MPG (US) | -- L/100Km | -- Km/L
Best Trip : 80.8 MPG (US) | 2.91 L/100Km | 34.35 Km/L
Old 10-17-2012, 02:07 PM   #283 (permalink)
BamZipPow's Avatar
Wink
It's one of the last things I've been playing with. Don't want too many irons in the fire...because I won't have enough tape to keep it all on if something fails to hold.
Partial rear wheel skirts/deflectors?
The Following User Says Thank You to BamZipPow For This Useful Post:
HyperMileQC (10-17-2012)
Old 12-21-2012, 08:37 PM   #284 (permalink)
BamZipPow's Avatar
Since the wet/rainy, cold weather is setting in, I think my 2x3 studs have been warping and changing the gaps on the hatch. There's been some rain intruding into the bed and it got me thinking on what might be the best way of eliminating the direct rain intrusion into the gap of the hatch and sides. I came up with some base board...about $12 worth. Used 4 strips of 4' each. Hopefully the sun won't beat them up too much over time.
A quick mockup fer measurements...
Screws every 6"...
Overlap...
Thinking about cutting up some strips of FRP into to reinforce the baseboard. It won't go all the way up to the sealing edge but just up the where the original gap begins. This should reinforce the baseboard to keep it from flipping up and ripping out of the screws.
aerohead (12-27-2012)
Old 12-21-2012, 08:44 PM   #285 (permalink)
BamZipPow's Avatar
Oh...I had to redo the top fastener fer the access doors...went from the vertical slot to a horizontal slot. This allows me to pull the top gap cover down more before I lock the bottom of the access door in place.
Old 12-23-2012, 08:19 PM   #286 (permalink)
BamZipPow's Avatar
Had some time to work on the aero cap today.
Got both the rail gap seals in place. It's projected to rain tomorrow and it will be a good test to see how well I've engineered this setup. I've also trimmed the 1"x2" supports that were sticking out the back of the hatch and painted the ends black.
Flattened out the lift brackets and secured them to the inside of the rail instead of the bottom side...
Put my hatch stops on the main support (where the lifts secure to) using 2 Strong Tie A12 brackets. My original ones were still the flat metal pieces that I had put on the rear portion of the main rails. If you weren't careful, it would bite you every time. Also, the rear window would snag on the stops when lowering the hatch.
Thinking about painting the right side black as well. At least it will match the left side.
Old 12-25-2012, 08:27 PM   #287 (permalink)
BamZipPow's Avatar
Talking
Some serious rain last night...hatch gap seals held up great! No leaks there. I did have some dripping from one of the access door hinges. Some Tyvek tape will take care of that.
Here's what the aero cap looks like painted black on the sides...with the access doors painted black, too!
I need to work on a tailgate seal where the rear plexiglass and tailgate meet. Need to keep the blow back from infiltrating that gap and gitting crud over everything in the bed. One solution was gonna involve drilling into the tailgate but I think I have something a little better than that. I'm gonna use 2 layers of tape that will stick together on the tailgate. The side profile will look similar the a lower case "h" and should be sturdy enough to stand on it's own. Maybe some rubber strips might help...we'll see.
Old 12-25-2012, 09:09 PM   #288 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 19.36 mpg (US)
Glad to have a chance to jump in momentarily and say I always enjoy that this thread pops up on my subscription list reading.
With a standard bed topper (otherwise body conforming) I bought some weatherstripping for the tailgate to body interface as the dust was becoming too much. The topper door to tailgate isn't that well-sealed (just a flap), but the dust is down noticeably by the tailgate full seal.
2004.0 7,940-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock. 187,000 miles/4,800-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (21-mpg avg past 41k)
Fuel Log
The Following 2 Users Say Thank You to slowmover For This Useful Post:
BamZipPow (12-25-2012), Xist (12-27-2012)
Old 12-27-2012, 04:47 PM   #289 (permalink)
black paint
Bam,she's startin' to look like 'KIT',so we'll have to keep a look out for David Hasselhoff, 'n make sure he doesn't drive off with her by mistake.
It's fun to watch your fabrication evolve.'looks like money in the bank!
BamZipPow (12-27-2012)
Old 01-06-2013, 12:03 AM   #290 (permalink)
BamZipPow's Avatar
Wink
The hatch has developed a leak on the left side. I'll need to sit inside the bed and figure out where it's coming from...
Here's what my tapered aero cap looks like from behind...
aerohead (01-07-2013), HyperMileQC (01-06-2013), slowmover (01-06-2013)
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
