Old 12-08-2010, 06:17 PM   #21 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Much better. I wish I’d done mine this way.
Back on your question. You could slope your cap down from the centerline out but you can’t get too crazed about it. I did some three-dimensional trig on the problem.
You have established a ten degree slope on the centerline. This is good. The air flow should stick like Super-Glue. By my calculation, you could slope down away from the centerline at an eight degree angle (about a 1-in-8 slope) and maintain less than a twelve degree (1-in-5 slope) angle relative to the top of your cab, so the air flow should stay attached to the end. If your truck is 80 inches wide that would allow you to lower the height at the rail by 5 inches from the centerline.
Nice thing is it will shed rain like a duck.
If you read the thread about “commercially produced aero cap” you’ll see the evolution of Bondo’s cap. I can’t seem to find the video of it in the wind tunnel but I seem to recall seeing the smoke sticking to the cap all the way to the lip. That would make it the gold standard. Now Bondo held the height at the rails to the same as the centerline, but he is trying to maximize internal (payload) volume rather than seek the maximum wake area reduction.
Somebody (I believe it was Frank) posted some tips on heat-bending coroplast. This might be useful bending that Texas-sized political sign into a righteous cap.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
BamZipPow (12-09-2010)
Old 12-08-2010, 11:17 PM   #22 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 current (2018) - '98 Toyota T-100 SR5
90 day: 19.99 mpg (US)
Send a message via ICQ to BamZipPow
Things I know I need to account fer in the next version are...
Front support rail fer hatch hinges
Drip guard/rail fer the hatch
Plexiglass/Lexan windows (clear window tint to protect from scratches) flush to outside coroplast layer
Possible to use existing glass assemblies from other vehicles (Maxima's long sunroof comes to mind) with a possibility fer a defroster grid
Easily disassembled/reassembled
Basic latch to keep the hatch from opening on it's own (not sure if I want to make it lockable or not)
Old 12-09-2010, 09:00 AM   #23 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by BamZipPow View Post
Piccie at 40mph...
BZP, you have a lot of sticks in the fire: ducktail + half tonneau, curved aero lid, not to mention other body mods.
In the pic above was the tailgate up or down? The way it's buckled down in back between center and side supports makes me wonder whether that was due to (a) vacuum effect underneath or (b) positive pressure above. If (b) that would suggest attached flow. Tufts would be helpful. A passenger with a video camera could be very valuable.
Our trucks are very similar. I have an 02 Tundra xCab. I believe our cab and bed body dimensions are the same. This is one aerocap design I have in mind.
Cheers
KB
The Following 5 Users Say Thank You to KamperBob For This Useful Post:
HHOTDI (06-08-2014), HighMPG (09-14-2011), JazzmanJames (02-17-2013), mcrews (09-17-2011), slowmover (12-13-2010)
Old 12-09-2010, 02:49 PM   #24 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
The tailgate was up.
I would have to guess b since I could see where the air was pushing it down as I was speeding up.
Yer aerocap design looks good. I guess yer approach is similar to a tonneau that caps over the sides...except the sides are extended up from the bed rails.
During some brain storming...I was thinking about the same design but taking an actual tonneau and testing it out with the raised sides. I guess it would be pretty simple to build up a rounded shape on top of the tonneau then...
I guess that would be one way to approach current tonneau owners. Make a kit that made use of their tonneau to make it more aerodynamic. As I think about it...it wouldn't work because the width of the cab is smaller than the width of the bed.
Old 12-09-2010, 03:44 PM   #25 (permalink)
Recreation Engineer
KamperBob's Avatar
My Tundra came with nice fiberglass tonneau courtesy of the original owner. It helped my high score of 22 highway despite the EPA sticker. Being a 4.7L 4WD model I suspect further improvement is high fruit. Still, it's fun to think and rethink possibilities. I sold that cover because it's not 5th wheel friendly. Removal, storage and reinstallation were solved problems but a lot of hassle. I have a short cap that I may yet annex for off-towing season. Given other priorities and current situation right now, however, to just get through this Winter I'll probably just put my toolbox back on the front of the bed and close off the rest of the box to keep snow out. The short cap does create a blind spot that bothers my wife when she needs to drive it so in the grand scheme I'll probably have something to share about that mod before long.
Cheers
KB
Old 12-10-2010, 05:47 PM   #26 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Gitting ready to sacrifice a single sheet of coroplast and reusing the 1x2 wood from my test belly pan to make a quick frame/cover fer the hatch. I should be able to make the sides and compute the angles I need to taper the main rails to.
Old 12-13-2010, 05:02 PM   #27 (permalink)
angles
Well...the post is just to hold it up since I'm working by myself and it just happened to be handy.
I guess it could be lowered...but what is the ideal angle of the cap? I guess the angle would be some where between 10° and 15° based on the calculations I performed earlier.
I guess I could make the next version from this to an adjustable angle to see what would be ideal. Obviously if I want that to happen, I'll have to keep spare side panels available to adjust the cap angle to...
It's really about tangent angles at any given point along a progressively-steepening curve up to a maximum of 22-degrees.But that's also the hardest to construct.
Dr.Kamm recommended no more than 10-degrees and proceeded to break his own rule.
Dr. Hucho suggests no more than 15-degrees.
I know from experience,that at 13-degrees over that much span,you'll get immediate separation and then re-attachment downstream with a locked-vortex in between.
With straight angles it's all a compromise.And Frank is totally correct in that if you push the angle too steep you get separation with zero re-attachment and little if any benefit.
My cover that you saw at Burger King has zero separation.If you can stand to build curvature into the cover you'll get the biggest bang for the buck.
BamZipPow (12-13-2010), KamperBob (12-13-2010)
Old 12-13-2010, 08:16 PM   #28 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Got my front support frame roughed out...the posts will be cut down to the wood support bar.
Goal posts!!
Rear quarter shot...
A quick mockup...
Rear shot of the mockup...
Old 12-13-2010, 08:40 PM   #29 (permalink)
90 day: 19.36 mpg (US)
My wife dislikes the non-window cap on mine for the same reason. Happily she dislikes a heavy diesel with a man trans even more so it's rather moot. As to "blind spots" I have had very good performance from modifying stock mirrors with:
Blind Spot Mirror Specialists - Safety Mirrors Online.com
Takes about three days to get used to. The larger the mirror the better as "distortion" is lessened. No more looking over your shoulder to check blind spot!!
Keep it rolling BZP!
2004.0 DODGE Ram QC/LB 2500 2WD/NV-5600 305/555 ISB. 7,940-lb. Stock. 200,000 miles/5000-hrs @ 40-mph average.
1990 35' Silver Streak TT 7,900-lb.
11-cpm solo & 19-cpm towing; 21-mpg average past 54k-miles
Sold: 1983 Silver Streak 3411
Old 12-13-2010, 09:51 PM   #30 (permalink)
Recreation Engineer
KamperBob's Avatar
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
