Old 06-28-2014, 05:05 PM   #331 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Right side is almost done. I still have the eye bolt locking mechanism to install.
Open...
Closed (except not locked in place yet)...
Hopefully I'll git done with both sides to hook up the trailer fer a quick test run tonight.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (06-30-2014), jedi_sol (06-28-2014), MobilOne (11-12-2015)
Old 06-28-2014, 09:53 PM   #332 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Both gap covers are installed. Not quite the fit I had in mind but there's enough fer me to work with.
A quick mock up with the trailer...
Both covers opened...
The Following 5 Users Say Thank You to BamZipPow For This Useful Post:
a8ksh4 (06-28-2014), aerohead (06-30-2014), jedi_sol (06-28-2014), MobilOne (11-12-2015), UltArc (06-28-2014)
Old 06-29-2014, 04:52 PM   #333 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Gap cover locks in place...gap cover close to the bed panel.
Clear cover on top now...
Gap cover rail supported at the end of the aero cap side panel...
The red tape on the gap cover rail is a safety item when the gap cover is in the open position.
Eventually I'll git some lift off hinges so I can easily remove the gap covers and leave the support rail in place.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (06-30-2014), MobilOne (11-12-2015)
Old 06-29-2014, 06:11 PM   #334 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
...and one rear shot!
Old 06-29-2014, 07:22 PM   #335 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Had to go git gas so I pulled the gap covers off of the rails. Only 18 screws...
I had an older couple in a van chase me down fer a few blocks. After gitting their eye full and making their comments, they turned around and went on their way.
Old 06-30-2014, 02:32 PM   #336 (permalink)
latest aero mods
Bam,if you have time,install a second fuel gauge to measure the gallons you'll be 'producing' on the upcoming trek!
Another 'Independent Texas Oil Producer.'
Fun!
I won't rest until I hear some updates from the road.Great going!
I suspect that there will be a lot of photos taken between now and when you return home.
BamZipPow (06-30-2014), MobilOne (11-12-2015)
Old 12-16-2014, 12:16 PM   #337 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Finally putting some effort to rebuild the upper gap cover between the aero cap and trailer.
A quick view of what it might look like using some 1"x2" lumber.
The upper width is 35.75" while the rear upper width is expected to be 30.75" and about 45" long. I have enough acrylic to cover the frame once I have the frame cut and beveled. I'm thinking about attaching the acrylic panels on with silicone adhesive and maybe about 4 screws per panel just to make sure the panels don't take off on on their own.
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 01-17-2015, 02:09 PM   #338 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
They say imitation is the sincerest form of flattery, right?
Pinewood derby truck fer my son...
Yes, I know it won't really help with aerodynamics as the speeds the derby runs aren't fast enough fer it to play a major factor. He did want his entry to look just like my truck and aero cap.
I'm just using a piece of Tyvek and rubber cement to git the basic shape. It started out as a scrap piece of wood...then transitioned to some scrap Foamular...and now scrap Tyvek.
aerohead (01-17-2015), MobilOne (11-12-2015)
Old 01-17-2015, 04:15 PM   #339 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.23 mpg (US)
This is so funny! Last night, my gf and I were killing time at Michaels and they have a whole section for pinewood derby. Of course we reminisced of those days (not sure why she had one, since she obviously wasn't a boy scout!). My first thought was of course what I could have done with my aerodynamic knowledge!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following 2 Users Say Thank You to jeff88 For This Useful Post:
BamZipPow (01-17-2015), MobilOne (11-12-2015)
Old 01-18-2015, 06:44 PM   #340 (permalink)
90 day: 31.19 mpg (US)
The kid who won one pinewood derby simply made the smallest car that he could and filled it with as many weights as he could. Of course, Cd is important, but he seemed to have some understanding of CdA.
The Following 2 Users Say Thank You to Xist For This Useful Post:
BamZipPow (01-18-2015), MobilOne (11-12-2015)
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
