Old 03-05-2008, 07:49 PM   #1 (permalink)
Paulywog
sip-n-go - '88 Honda CRX
Last 3: 10.06 mpg (US)
crx coroplast belly pan finished!
Just finished belly pan using 3 sheets of 1/4" 'natural' color coroplast. Hubcaps too.
Pics @ http://www.paulstoys.blogspot.com
Mechanical Madness
The Following User Says Thank You to paulwelkins For This Useful Post:
aerohead (05-15-2015)
Old 03-05-2008, 08:51 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Nice job! It's looking good so far.
Old 03-05-2008, 08:59 PM   #3 (permalink)
I'd rather be biking
boxchain's Avatar
Lexie - '98 Honda Civic LX
90 day: 39.46 mpg (US)
Beater Hauler - '92 Isuzu Pickup
Rentaclipse - '08 Mitsubishi Eclipse ?
90 day: 28.28 mpg (US)
Fahrt - '83 BMW R80 ST
Nice work!
Your car stands are frightening though
My bike runs on dihydrogen monoxide.
I like to use these acronyms
Old 03-05-2008, 09:02 PM   #4 (permalink)
Excellent work. Where do you get your coroplast? I haven't been able to find it around here. Have you had a chance to put a lot of miles on the setup? I would be a bit concerned about its proximity to the exhaust and catalytic converter.
Old 03-05-2008, 09:15 PM   #5 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Looks good. Have you driven far/long with it installed yet?
Old 03-05-2008, 10:03 PM   #6 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Very nice work.
Coast long and prosper.
Old 03-05-2008, 10:06 PM   #7 (permalink)
Paulywog
I'm in the seattle area. Laard plastics sells 4x8x1/4" sheets for about $12 per.
I shook the crap out of the car and chucked the wheels before going underneath. I'm nota fool, just cheap. Besides my 25 mile commute today, with about 10 minutes of stop and go, outside temp in the mid 50's, the temp guage didn't move. Fan is probably working overtime I'm guessing. Will work on installing radiator vent with cable adjust from inside next.
Mechanical Madness
Old 03-05-2008, 10:21 PM   #8 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Paul... That/Your blog = awesome!
It's a collection of so many things I'm into... 'bents, small motorized vehicles, micro boats...
The Wheel! In freaking sane! My roommate is looking at me funny because I'm getting excited over a concept centuries old
That, might be a weekend project for me Plus, I like your name - it's just something I grew up with
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 03-05-2008, 11:03 PM   #9 (permalink)
Paulywog
The wheel...build it, you will have fun, damb it.
Mechanical Madness
Old 03-16-2008, 03:40 PM   #10 (permalink)
So, where does the engine and exhaust heat go? Is it sucked out through the gap between front and back sections of Coroplast, or past gaps around exhaust pipes/mufflers?
Couple of thoughts:
Near heat sources you may suffer some Coroplast melting. Time will tell, but you could add edging to the Coroplast in the form of aluminum foil tape. This would seal the edge, keeping moisture and crud out, and be a good way to dissipate heat from any hotspots, aluminum foil being a superb heat conductor.
If you need to stiffen the Coroplast, insert thin dowel rods from a lumber yard. Alternatively, use L bracket or extruded aluminum, orienting it to act as flow fences to shunt the under-car airflow gently out to the sides. Google for Ferrari aerodynamics.
What has this done for fuel economy so far?
What about noise level in the car, at freeway speed?
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 05:13 PM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
