Old 10-10-2008, 12:58 PM   #1 (permalink)
jeepin xj (pro jeep ecomodder/hypermiler) - '95 CHEROKEE XJ
Last 3: 21.58 mpg (US)
any 4.0 jeep guys on here? do the deep cycle battery?
Ive seen some jeep guys do the deep cycle battery have any of you removed alternator ive thought of trying this mod but how do you removed some pullies and re route belt, ac or extra fan pulley once you do the electric fan mod. Or what else have you 4.0 jeep guys done for FE.
-I ve done the remove front driveshaft thing
-electric fan
-removed all interior and did rino lying on floors so no carpet or rear seats or belts
-50 psi all 4
-no spare tire since i am local driving
-hho with efei to lean 02 and map
-all new sensors high output wires, plugs cap rotor coil
-all low viscosity fluids AMSOIL
-advanced timing manually
-3 "Warm air intake
-no lift stock tires aluminum rims
Old 10-10-2008, 03:05 PM   #2 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
You will freak out the ECU removing the alt. The voltage regulator is built into the ECU, so no alt, and the ECU thinks its dying so it pumps in voltage to the stator trying to make it generated juice.
Once removed though, you could just run a shorter serp belt
Old 10-13-2008, 10:20 AM   #3 (permalink)
Ive seen some guys do it, i was just curious on how, also the injector mod what is that
cheap, light-weight EV battery? eta Fossil Fuel Free 5 05-15-2009 01:00 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
Hey Jeep guys...........didjaseethis? metroschultz General Efficiency Discussion 3 05-19-2008 11:02 AM
