Old 06-10-2008, 03:50 AM   #21 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
thebrad -
Originally Posted by thebrad View Post
Willing to try it "for science" if you can give me the XGauge coding.
I did some googling but no luck. 1996 Civic codes are probably harder to find. I think this is a Civic Tuner Forum question.
CarloSW2
American Solar Energy Society
Old 06-10-2008, 10:20 AM   #22 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Without a gauge to show actual FE, I can only guess, but coasting in gear shortens the distance I can coast. When stopped, all I can go by is the tach: in gear is usually around 800 rpm vs 1000 rpm in neutral.
It also seems to depend on the speed sometimes; if I'm doing <45 and I coast in gear, the tach drops ~500 rpm but > 45 it doesn't drop noticeably (maybe 100?) and there's the engine drag.
Until I get the time to put a 'Guino together (I'm not paying for a SG), I'll just stick with my "neutral coast, stop in gear with engine on" policy.
Old 06-10-2008, 12:10 PM   #23 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
if i need engine braking, of course, coasting in gear is the best, with or without injector cutoff as needed.
if i don't need engine braking, of course, coasting in neutral is the best, with engine off or idling as needed.
any vehicle getting better mileage coasting in gear, would have to have some kind of over-running clutch system, and a very smart ECU, that idled the engine at the same time.
the only one i have driven that did this was an Audi turbo-diesel with the transmission in E.
Old 06-12-2008, 03:14 AM   #24 (permalink)
Curious....
koihoshi's Avatar
DoesNotHaveANickname - '99 Escort ZX2
It definitely has advantages. Heading down a small hill that goes slightly up hill you can coast down, gain speed, level out at top and then go back into gear (Or just slowly let out the clutch and match rpms).
I've started coasting a LOT more as I come to stops, cover large distances when approaching traffic and in situations where it makes no sense to be engine braking and what have you.
This has saved me some good gas mileage So to answer the originating question:
YES
Old 06-12-2008, 09:20 AM   #25 (permalink)
Enthusiast Kinda
2005 HCH - '05 Civic Hybrid XL
90 day: 46.19 mpg (US)
Send a message via MSN to MasterAlex
kinda like a hybrid
Old 06-12-2008, 11:39 AM   #26 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Don't do EOC in an automatic-equipped car. Coasting in neutral should be fine; I've been doing it for a long time in the Forester at speeds up to 75mph (we get some steep hills here in the Appalachians) and suffered no ill effects, but the front end of the tranny has to be turning to keep the rest of the tranny lubed. You can coast with the engine on, and turn the engine off at lights, but when rolling, the engine should be on.
And yeah, it's worth it. A Forester is heavy and shaped a bit like a LEGO block, but I've dragged its mpg up from an average of 25 to about 29.1.
You're not in front of me...
I'm 25,000 miles in front of you.
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 10:39 AM
Why won't my engine start on neutral at 50+ MPH? blackjackel Hypermiling / EcoDriver's Ed 18 05-16-2008 09:14 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Brakes, EOC (engine off coasting) and reserve vacuum Lazarus Hypermiling / EcoDriver's Ed 5 01-24-2008 08:17 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
