Old 09-30-2010, 12:27 PM   #21 (permalink)
Originally Posted by soubi7string View Post
is a 92 oldsmobile cutlass ciera s safe to coast in N then shift back into drive?
First check and see whether or not it's OK to tow your car in neutral. If it is OK then you can coast in neutral with the engine running, but with the following important considerations: There is no problem with the coasting in neutral per se; the potential problem comes when putting it back into drive. You can only put it back into drive when you are completely stopped or almost completely stopped (under 10 MPH). That way when you do put it back into drive it will go into first gear. If you do it while the car is moving at higher speeds you will damage the transmission. I learned this the hard way, and it was an expensive lesson.
Practical application of this would be in coasting in neutral to a known stop sign where you know you will have to stop. It is not recommended that you try it while approaching a red light, because if the light turns green and your speed is over 10 MPH you cannot (or should not) put the transmission back into drive unless you are almost stopped.
Remember, rebuilding an automatic transmission is one of the most costly repairs that any vehicle might experience. Ruining your transmission is not worth the few dollars in fuel that you might save.
Old 10-01-2010, 02:21 AM   #22 (permalink)
yeah um, forget that mess
why not say something interesting? like Spatu-la?
Old 10-01-2010, 08:34 AM   #23 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I used to neutral coast in a '94 Grand Prix SE... had no problems with putting the transmission into gear at higher speeds... I don't think I've ever heard of a transmission that couldn't be put into gear while coasting, actually.
Old 10-01-2010, 02:41 PM   #24 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
In my Jeep, if I neutral coast, it goes back into 3rd, not 4th at first, so I just have to give the gas a good tap to rev-match it first. I rarely neutral coast though, as it would help most around town, but at 30 or so, the Jeep actually coasts better in gear (engine pretty much idling).
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
NO Damage to auto transmission by EOC ScottC33 Hypermiling / EcoDriver's Ed 35 07-09-2009 02:42 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
Coasting in Neutral (Auto transmission) regor EcoModding Central 0 10-11-2008 10:52 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
